Re: Any DRAW-thru slant 6 turbo setups here?
[Re: polkat]
#960769
03/28/11 12:44 PM
03/28/11 12:44 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Why draw through?
Blow through is the way to go.
[Re: pishta]
#960772
03/29/11 02:45 AM
03/29/11 02:45 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Can you still get turbo's that are set up for draw through? I know a bunch of old school stuff was setup for that, but I don't think I've seen a new turbo setup for draw through in at least a decade. Just curious.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#960773
03/29/11 03:21 AM
03/29/11 03:21 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Just get a replacement turbo for an early 3.8 litre turbo buick, they were draw through. I see no problem in a draw through, and would build one if really doing it cheap and not needing huge power. You have to use a big enough carb, you don't want a restirction on the suction side. 3.8 Buicks used a Quadrajet.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#960774
03/30/11 02:01 PM
03/30/11 02:01 PM
feets
Senior Management
Senior Management
Irving, TX
The McInnes book is from the early 80s. I've got it and it's spotty at best. The draw through Buicks were replaced with blow through for good reason. Remember the old turbo Trans Ams? They had a draw through 301 and got pounded by the underpowered 6.6 T/As. Very few of them retain the old draw through setup.
Yes, you can make it work. However, if you're going to make the effort to turbocharge something do it right. You will be much happier in the end.
[Re: feets]
#960776
04/04/11 12:50 AM
04/04/11 12:50 AM
Posts: 60 Tolstoy, SD
turbo66valiant
Tolstoy, SD
[Re: turbo66valiant]
#960777
04/06/11 11:36 AM
04/06/11 11:36 AM
jyrki
Finalnd, Perkele
We had a draw through 318 years ago that ws basically stock and run high 13's in a '71 cuda. My opinion still is, that if you want to do a junkyard turbo build up easy, I would build a draw through. Get a carb and a turbo and some tubing from junkyard and build it; you'll end up spending less money thna th eprice of a new cam and definitely gain more performance.
[Re: jyrki]
#960778
04/06/11 12:51 PM
04/06/11 12:51 PM
feets
Senior Management
Senior Management
Irving, TX
Stock cams work fairly well with a turbo. You can build a blow through system cheaply and make more power than a draw through.
[Re: feets]
#960779
04/07/11 02:43 AM
04/07/11 02:43 AM
jyrki
Finalnd, Perkele
The carb needs changes, and the fuel supply needs to be pressurised, so itäs definitely more work. And if you are not trying to reach the moon, I still believe that a draw through set up needs less effort. Actually, I will most likely build a /6 with a draw through for 2012. I agree that if you are looking for the better set up, it's blow through, but it doesn't mean that a draw through is useless. A friend of mine built one with a centrifugal and run 9's with it. Later he converterd it to blow through with an intercooler, and cut about 0.5 seconds off his ET.
