Can you guys rate my 383 build...
#960648
03/27/11 11:35 PM
03/27/11 11:35 PM
Posts: 2,782 USA
JoesMopar
USA
Ok, I have parts, so this is pretty much the way the build is going to be, not much in the room of changing things around now... I did as much research as I could....with the help of you guys Anything with a "?" beside it is still not for sure...so I would need some input 383 .030 over std rod/mains ARP rod/main/head bolts Edelbrock closed chamber heads Cometic .027"/4.35" head gaskets (?) SpeedPro 2315 (1.920" CH) stock deck height (squared to crank) balanced assembly Comp XE 274/286 cam/lifters Performer RPM intake 650 Thunder Series Carb (?) MP igniton conversion kit Factory HP manifolds (?....any issue with the angled plug heads? would rather not use headers) Comp Double Roller I'm getting 9.57:1 CR ASSuming the piston is .01 in the hole with the 2315 pistons. That would also figure a .037" quench as well....correct? How does this sound to you guys?
Re: Can you guys rate my 383 build...
[Re: JoesMopar]
#960649
03/27/11 11:45 PM
03/27/11 11:45 PM
RapidRobert
sounds pretty good. I'd mockup & check actual deck height b 4 ordering the cometics to keep your quench. What octane? the angled plugs MAY pose a prob (someone will chime in). I am not a cam guy. I'd get a 3" mandrel ex system from the HP manifolds back like Andy did on his build (it's in the archives) & will need X pipe/proper muffs/rear resonators to keep the noise manageable. Yes .037" quench is perfect (measured in each hole) . Dont balance till you get the valve reliefs and or piston deck milled (if needed) EDIT you'll prob want the CR to b higher (forgot about the alum head effect)
[Re: JoesMopar]
#960651
03/28/11 02:27 AM
03/28/11 02:27 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
Just curious, have you already purchased the pistons? According to Mancini Racing, these pistons have been backordered for several months now. Summit has some, but the 30 over ones are about $500 for a set of eight. Evidently they have more of the 40 and 60 over pistons, as those are $40 per piston instead of $60 for the 30 over slugs.
[Re: RapidRobert]
#960655
03/28/11 10:38 AM
03/28/11 10:38 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Why would he need to mill the piston decks ??? You're the only loon I know that is milling quench dome pistons for use with a closed chamber head. (but I do have to admit I suggested doing that to a person doing a 440 that has quench head pistons already because his deck heights are all over the place due to crank stroke difference and/or connecting rod difference)...
Unless he has serious piston to wall clearance I can't see a piston that is .010 in the hole tipping enough to come above the deck and hit a head that is .027 above it.
One thing he does need to check is piston to valve clearance because those pistons don't have valve reliefs.
As far as the build , bigger carb (a 750 but NOT the performer series Ebrock carb) and a different cam, something in a solid , like the MP .528 .
[Re: JoesMopar]
#960662
03/29/11 01:01 AM
03/29/11 01:01 AM
DaytonaTurbo
Manitoba, Canada
You don't HAVE to run higher compression with the aluminum heads, just you are able to run a bit higher compression without detonating. Quote:
The gear is a 3.23 with a 2500 stall. That cam should be just a little larger than a stock HP cam, so I'm not sure why 10.5:1 CR is really needed?
That cam is notably bigger than a stock HP cam, and with 9.5 compression, 2500 stall and 3.23 gears, it will be soft in the bottom. Now if you had 440 cubes, 9.5 compression, 2500 stall and 3.73 gears I'd say you'd be okay with that cam. It's very easy to over cam a 383 and like I said, a lot of guys on here are having good luck with the comp xe268 in their 383's. I think a couple guys from here even have youtube videos of theirs.
[Re: DaytonaTurbo]
#960663
03/29/11 01:15 AM
03/29/11 01:15 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The Crower 271HDP, 222/234@.050 .486/.496 lift 112 centers comes highly recommended too...
[Re: JoesMopar]
#960664
03/29/11 02:46 AM
03/29/11 02:46 AM
rss
Seattle, WA
I may save the 2315's for another build since they were basically given to me (not free but cheap)
If you decide to go with the KBs and want to unload the 2315s let me know. I'm in the middle of my own 383 build at the moment. Pretty similar to yours but I'm using my original open chamber 906 heads. Good luck with yours.
[Re: JoesMopar]
#960665
03/29/11 08:21 AM
03/29/11 08:21 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I ASSumed the piston depth based off a measurement I took from the original pistons and then added the CH of the new pistons. I know I'm not going to know for sure until I get it back from the machine shop, which is why I haven't ordered the head gaskets yet.
I may go with headers, not sure which ones would fit or not. This is a manual brake, manual steering '68 Sat.
I'm not going to be racing this thing at the drag strip. It's a pretty cheap car that I don't have much money invested in and felt like making something to cruise and go fast in every now and then.
I usung the Summit headers on my 440-6. They fit w/o any problems. Even when I had PS. I'm also using a mini-starter. The 268 comp cam might be a better choice w/ your combo or the solid 528 if you don't mind spending a few more $$$ on adjustable rockers.
[Re: Mr.Yuck]
#960667
03/29/11 10:03 AM
03/29/11 10:03 AM
JohnRR
U.S.S.A.
You shouldn't compare a 440 and starter clearance using a mini starter to a 383 , the headers are closer to the block on the 383. I TRIED to use a mini starter with a set of 1 3/4 primary headers and I couldn't get the header on the engine with a mini starter .
