Page 1 of 3 1 2 3
Can you guys rate my 383 build... #960648
03/27/11 11:35 PM
03/27/11 11:35 PM
USA
JoesMopar Offline OP
USA
Ok, I have parts, so this is pretty much the way the build is going to be, not much in the room of changing things around now...
I did as much research as I could....with the help of you guys
Anything with a "?" beside it is still not for sure...so I would need some input
383
.030 over
std rod/mains
ARP rod/main/head bolts
Edelbrock closed chamber heads
Cometic .027"/4.35" head gaskets (?)
SpeedPro 2315 (1.920" CH)
stock deck height (squared to crank)
balanced assembly
Comp XE 274/286 cam/lifters
Performer RPM intake
650 Thunder Series Carb (?)
MP igniton conversion kit
Factory HP manifolds (?....any issue with the angled plug heads? would rather not use headers)
Comp Double Roller
I'm getting 9.57:1 CR ASSuming the piston is .01 in the hole with the 2315 pistons. That would also figure a .037" quench as well....correct?
How does this sound to you guys?
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960649
03/27/11 11:45 PM
03/27/11 11:45 PM
sounds pretty good. I'd mockup & check actual deck height b 4 ordering the cometics to keep your quench. What octane? the angled plugs MAY pose a prob (someone will chime in). I am not a cam guy. I'd get a 3" mandrel ex system from the HP manifolds back like Andy did on his build (it's in the archives) & will need X pipe/proper muffs/rear resonators to keep the noise manageable. Yes .037" quench is perfect (measured in each hole) . Dont balance till you get the valve reliefs and or piston deck milled (if needed) EDIT you'll prob want the CR to b higher (forgot about the alum head effect)
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960650
03/28/11 12:54 AM
03/28/11 12:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
w/ robert but want to add a few points. It's going to want more than a 650 carb, upgrade to a 750, my suggestion would be a holley 3310 vacuum secondary carb, and please invest in a tuning kit to get it dialed in correctly.
Which cam do you have? Do you mean the comp xe274h? That cam in an aluminum headed 383 would want more like 10.5 compression. With 9.5 compression it's going to be a little soft on the bottom with that cam. And it's going to want to rev. IMO not the best cam choice for running hp manifolds. A lot of members have had good success with the comp xe268h in their 383's, you might want to think about doing that cam intead, especially if you really want to run the hp manifolds instead of headers.
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960651
03/28/11 02:27 AM
03/28/11 02:27 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Just curious, have you already purchased the pistons? According to Mancini Racing, these pistons have been backordered for several months now. Summit has some, but the 30 over ones are about $500 for a set of eight. Evidently they have more of the 40 and 60 over pistons, as those are $40 per piston instead of $60 for the 30 over slugs.
Re: Can you guys rate my 383 build... [Re: DaytonaTurbo] #960652
03/28/11 02:48 AM
03/28/11 02:48 AM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
I 2nd the 268 cam.
Much better low end.
If unsure, call Engle and have them make you a custom split. They wont steer you wrong. Great guys and knowledgeable. (No, I am not shilling for them..LOL. I had some issues with cam choice in my 451 build, and they were spot on with their recomendations. I couldnt be happier.)
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960653
03/28/11 07:31 AM
03/28/11 07:31 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
It looks like you have that cam already, so you'll need some rear gear and a decent stall if automatic. I agree with the Holley 3310. As Robert said you need to mock up 1st. How did you figure the piston depth?
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960654
03/28/11 08:14 AM
03/28/11 08:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What gear and stall? That cam is going to want some of each. Your carb is also a tad small. I'd run a 750DP. And Manifolds? Is this in a Duster? That cam is going to like to breath, you are dumping all that fuel and air into the cylinder, once it burns it will need to get out. Headers would be better but Hey it's your car. I;d say if you want to use that carb and mani's drop down on the cam some.
Coming soon!!!!
Re: Can you guys rate my 383 build... [Re: RapidRobert] #960655
03/28/11 10:38 AM
03/28/11 10:38 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Why would he need to mill the piston decks ??? You're the only loon I know that is milling quench dome pistons for use with a closed chamber head. (but I do have to admit I suggested doing that to a person doing a 440 that has quench head pistons already because his deck heights are all over the place due to crank stroke difference and/or connecting rod difference)...
Unless he has serious piston to wall clearance I can't see a piston that is .010 in the hole tipping enough to come above the deck and hit a head that is .027 above it.
One thing he does need to check is piston to valve clearance because those pistons don't have valve reliefs.
As far as the build , bigger carb (a 750 but NOT the performer series Ebrock carb) and a different cam, something in a solid , like the MP .528 .
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960656
03/28/11 04:02 PM
03/28/11 04:02 PM
Slant6duster, holler how it turns out
Re: Can you guys rate my 383 build... [Re: RapidRobert] #960657
03/28/11 10:06 PM
03/28/11 10:06 PM
USA
USA
I ASSumed the piston depth based off a measurement I took from the original pistons and then added the CH of the new pistons. I know I'm not going to know for sure until I get it back from the machine shop, which is why I haven't ordered the head gaskets yet.
I may go with headers, not sure which ones would fit or not. This is a manual brake, manual steering '68 Sat.
The gear is a 3.23 with a 2500 stall. That cam should be just a little larger than a stock HP cam, so I'm not sure why 10.5:1 CR is really needed?
I'm not going to be racing this thing at the drag strip. It's a pretty cheap car that I don't have much money invested in and felt like making something to cruise and go fast in every now and then.
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960658
03/28/11 10:31 PM
03/28/11 10:31 PM
It's from the alum heads wicking away the heat much faster, may or may not want (measured) 10.5 but for sure higher than 9.5. higher CR is more squeeze and one of the main parameters of an eng's power and anytime you can run more w no probs def do it & w you being in the planning stage this is the perfect time. If you build a spot on long block then any addition/change/mod in the future IE cam/carb/intake/ign will only compliment your thoroughness w nothing left on the table. Measure the actual deck height/head CC's etc & go from there. Holler how it turns out for you
Re: Can you guys rate my 383 build... [Re: RapidRobert] #960659
03/28/11 10:49 PM
03/28/11 10:49 PM
USA
USA
Well, I kind of fell into getting these Speed Pro pistons.
Would it be beneficial to go with the KB 400?
I may save the 2315's for another build since they were basically given to me (not free but cheap)
I checked my CR with the 400's if I buy them, 9.8:1 with the 84cc head and .027 gasket AND since the piston is .012" shorter I am ASSuming now .022 in the hole...which would give a quench of .049"...not ideal probably but I wouldn't think it was too bad.
How about this option? Plus, the valve relief "problem" if it exists would be solved.
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960660
03/28/11 11:03 PM
03/28/11 11:03 PM
I may save the 2315's for another build since they were basically given to me (not free but cheap).
Oh that's the story of my life as I have parts (new and used) in every room ex the bathroom. yes you'll use em (one of these days ). What I'm doing w my 451 & which would b my suggestion is to go w the right KB's & mockup the short block & see what you actually have (deck and quench plateau height) & in conjunction w what is avail for gaskets machine for quench and the right CR for your app w your intended octane/cam (though I am not sure what CR to shoot for) then dissassemble/machine/reassemble/recheck/dissassemble and balance it/reassemble . This'll give you a long block that will not need to be touched and you can then play/experiment w the external additions and know that your foundation is perfect
Re: Can you guys rate my 383 build... [Re: RapidRobert] #960661
03/29/11 12:09 AM
03/29/11 12:09 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
if you are going to use the alum heads you have to go above 10-1 comp otherwise use the iron heads. carb is to small. little stiffer on the converter. you won't know a whole lot until you how far in the hole the pistons are. so with your deck height and crank rod combo then you will know that.myself i would not build a mopar without talking to hughes engines. you can use your GM comp cam or get a scary name like voodo. i would stick with mopar specific builds. call hughes, tell them what you are wanting to do and use their free advice. just my
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960662
03/29/11 01:01 AM
03/29/11 01:01 AM
Manitoba, Canada
Manitoba, Canada
You don't HAVE to run higher compression with the aluminum heads, just you are able to run a bit higher compression without detonating.
That cam is notably bigger than a stock HP cam, and with 9.5 compression, 2500 stall and 3.23 gears, it will be soft in the bottom. Now if you had 440 cubes, 9.5 compression, 2500 stall and 3.73 gears I'd say you'd be okay with that cam. It's very easy to over cam a 383 and like I said, a lot of guys on here are having good luck with the comp xe268 in their 383's. I think a couple guys from here even have youtube videos of theirs.
Re: Can you guys rate my 383 build... [Re: DaytonaTurbo] #960663
03/29/11 01:15 AM
03/29/11 01:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The Crower 271HDP, 222/234@.050 .486/.496 lift 112 centers comes highly recommended too...
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960664
03/29/11 02:46 AM
03/29/11 02:46 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
If you decide to go with the KBs and want to unload the 2315s let me know. I'm in the middle of my own 383 build at the moment. Pretty similar to yours but I'm using my original open chamber 906 heads. Good luck with yours.
Re: Can you guys rate my 383 build... [Re: JoesMopar] #960665
03/29/11 08:21 AM
03/29/11 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I usung the Summit headers on my 440-6. They fit w/o any problems. Even when I had PS. I'm also using a mini-starter. The 268 comp cam might be a better choice w/ your combo or the solid 528 if you don't mind spending a few more $$$ on adjustable rockers.
Coming soon!!!!
Re: Can you guys rate my 383 build... [Re: Mr.Yuck] #960666
03/29/11 08:56 AM
03/29/11 08:56 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
why put out the cost for alum heads if you are not going to run higher comp?
Re: Can you guys rate my 383 build... [Re: Mr.Yuck] #960667
03/29/11 10:03 AM
03/29/11 10:03 AM
U.S.S.A.
U.S.S.A.
You shouldn't compare a 440 and starter clearance using a mini starter to a 383 , the headers are closer to the block on the 383. I TRIED to use a mini starter with a set of 1 3/4 primary headers and I couldn't get the header on the engine with a mini starter .
Page 1 of 3 1 2 3
