ignition trouble #960177
03/27/11 06:44 PM
03/27/11 06:44 PM
Nuevo leon,mexico,Monterrey
asesino Offline OP
asesino  Offline OP
Hi, i want know why my charger doesn't start until i release the key??
thanks
xASESINOx
Re: ignition trouble [Re: asesino] #960178
03/27/11 06:50 PM
03/27/11 06:50 PM
Kirkland, Washington
Pacnorthcuda Offline
check the bulkhead connector on the firewall--dirty/loose connection
Re: ignition trouble [Re: Pacnorthcuda] #960179
03/27/11 06:56 PM
03/27/11 06:56 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Check Ballast resistor.
Re: ignition trouble [Re: Pacnorthcuda] #960180
03/27/11 07:50 PM
03/27/11 07:50 PM
asesino Offline OP
asesino  Offline OP
thanks the bulkhead is well i thinks is the solenoid starter
xASESINOx
Re: ignition trouble [Re: superbeedave] #960181
03/27/11 07:52 PM
03/27/11 07:52 PM
asesino Offline OP
asesino  Offline OP
thanks have a MSD somebody have the diagram for the solenoid?
xASESINOx
Re: ignition trouble [Re: asesino] #960182
03/27/11 08:12 PM
03/27/11 08:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What year car?
Re: ignition trouble [Re: asesino] #960183
03/27/11 11:05 PM
03/27/11 11:05 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
sounds like the small red wire going to the MSD doesnt get power when cranking.
Re: ignition trouble [Re: 05dakota] #960184
03/28/11 05:49 PM
03/28/11 05:49 PM
asesino Offline OP
asesino  Offline OP
i think the trouble must be here
xASESINOx
Re: ignition trouble [Re: asesino] #960185
03/28/11 08:13 PM
03/28/11 08:13 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
what is that thing?
Re: ignition trouble [Re: 05dakota] #960186
03/29/11 05:09 PM
03/29/11 05:09 PM
asesino Offline OP
asesino  Offline OP
what is that thing?
I don't know what is the correct translation,
but there is connected the red wire coming from the batterie and it works when the key is to start
... the trouble that..... when i turn the key until start, the starter turns but not starts and turn and turn but don't start until i release the key ,i think the engine reaches to start because the spark of the coil and msd is very strong .....when i have the key in ignition i have power, but when i turn the key until start i lose it until return to ignition
xASESINOx
Re: ignition trouble [Re: asesino] #960187
03/29/11 09:55 PM
03/29/11 09:55 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
I admit I'm having trouble understanding you, but I don't speak Spanish. Your picture, I think was meant to be the firewall / fender mounted "starter relay" like this:
If the starter works, that relay is OK
It is not clear to me if you have spark when cranking?
On your ignition, you have TWO separate circuits from the key (ignition switch)
The DARK BLUE going to the coil resistor has 12V power when the key is in "run" and feeds power through the resistor to the coil
The BROWN going to the side of the resistor which feeds the coil is the "bypass" circuit and feeds power ONLY when the key is twisted to "start."
Re: ignition trouble [Re: Yancy Derringer] #960188
03/30/11 12:29 AM
03/30/11 12:29 AM
The DARK BLUE going to the coil resistor has 12V power when the key is in "run" and feeds power through the resistor to the coil.
You have an 'open" in this run (ign1) circuit from the ign sw to the bulkhead then out to and thru the ballast. The relay is the pic is not the prob.
Re: ignition trouble [Re: RapidRobert] #960189
03/30/11 01:55 AM
03/30/11 01:55 AM
Montana
Y
Y
Montana
!!! NO !!! Other way around. He has an open in IGN2, the bypass circuit (brown)
Re: ignition trouble [Re: asesino] #960190
03/30/11 09:20 AM
03/30/11 09:20 AM
thanks
You have an open in the ign1 (run) circuit. Start by checking for fire at the blue wire(s) terminal on the ign sw then both sides of the bulkhead
Re: ignition trouble [Re: asesino] #960191
03/30/11 09:52 AM
03/30/11 09:52 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thanks
El sintoma para esta falla esta en el circuito de "bypass" de la resistencia, teniendo o no la resistencia.
Nuestros vehiculos tienen dos puntos de alimentacion al sitema del motor. la Ignicion 1 que es la que opera regularmente y alimenta todo el motor y normalmente marcado con el cable azul. Este sistema alimenta la resistencia que varia el nivel de alimentacion de acuerdo a la temperatura del motor a la bobina para evitar recalentamiento. A medida que el motor esta mas caliente, la chispa requiere menos energia para encender la gasolina y de alli es que la resistencia de acuerdo a la temperatura pues disminuye el nivel de energia a la bobina, evitando que una energia constante la recaliente sin necesidad.
SIN EMBARGO, para el momento de arrancar el motor ( ign 2 ) si es recomendable maxima energia, y de alli el cable MARRON que llega a la resistencia, pasa por encima de esta para alimentar directamente la bobina con los 12 Voltios completos.
Si el vehiculo arranca al soltar la llave es que el circuito de ign 2 esta fallando y solo esta siendo alimentado en el momento de la ign 1.
La falla puede estar en el switche de encendido o en el conector maestro de la pared de fuego estando un poco flojo o sucio, o alguna seccion de estos cables rotos... este cable es de color marron y calibre 14
Aunque tienes MSD me imagino que para alimentar el cable rojo delgado que es el "trigger" que enciende el modulo usaste uno de estos dos metodos:
-Cable que alimenta el positivo de la bobina ( ya sea marron para modelos posteriores al 70 o azul en modelor previos al 70 ) unido a este cable rojo delgado del MSD
-Eliminacion de la resistencia y uniste tanto cables azul y marron que llegaban a la resistencia, provenientes de la cabina del vehiculo al cable delgado rojo del MSD
En ambos casos, el cable marron de Ign2 esta teniendo falla de alimentacion, perdiendo poder mientras el motor arranque esta operando
Re: ignition trouble [Re: NachoRT74] #960192
03/30/11 10:08 AM
03/30/11 10:08 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
ballast resistor only if it's the dual resistor type
Re: ignition trouble [Re: jlatessa] #960193
03/30/11 10:47 AM
03/30/11 10:47 AM
Montana
Y
Y
Montana
Come -- ON folks use your brains, please
THIS IS NOT THE BALLAST when the car will not fire "In start" but fires and runs "IN RUN"
Re: ignition trouble [Re: Yancy Derringer] #960194
03/30/11 03:04 PM
03/30/11 03:04 PM
asesino Offline OP
asesino  Offline OP
Yes, yes yes that's it the part to i try to say, I search it in google like a starter relay, but never appears, and then i think:... well i must be wrong in my translate ...f#"@% google..... i think the problem must be there, some wire don't be work, because the previously owners change the wires of the bulkhead and now have other the colors, i must will check wire by wire to find wich wire don't work and change it. but i need to know how is the function of every plug of the starter relay, the big screw goes to starter, and the middle goes to the small screw of the starter, but the last two small's plugs, i don't know where they go.
in a digram to i have indicates one of them goes to the motor windshield or the wiper, i don't remeber, but i think it's very strange.
well i hope you understand me guys, thanks for all your answers, tomorrow will upload some pics
xASESINOx
Re: ignition trouble [Re: NITROUSN] #960195
03/30/11 03:09 PM
03/30/11 03:09 PM
asesino Offline OP
asesino  Offline OP
What year car?
sorry bro it's a 71 thanks
xASESINOx
Re: ignition trouble [Re: jlatessa] #960196
03/30/11 03:13 PM
03/30/11 03:13 PM
asesino Offline OP
asesino  Offline OP
I don't have put ballast resistor, i have MSD
xASESINOx
