Re: Need advice / ideas on trimming torsion bar crossme [Re: NITROUSN] #959113
05/08/11 02:39 AM
05/08/11 02:39 AM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
I have a tko 600 kit and have none of the problems you have. Was yours an auto or 4 speed before? Did you buy the kit new from Keisler?
4 speed. Got the kit new from keisler
.....2 questions for you, placement of the motor mount brackets, behind, or infront of the engines mounting tab/bosses/ears when veiwing the engine from the front,...next, are you running a 70 B body K frame in a 69 Charger
motor mounts are in the correct place k-frame is not a 70 k-frame.
I ended up doing some cutting
Crossmember raised up and welded back together. I used 1/4" plate to reinforce it.
now look at how nice the headers fit. Just like they used to
before I installed the 5 speed.
next I will fabricate the new tunnel. Hopfully I'll have pics of this soon.
Re: Need advice / ideas on trimming torsion bar crossmember [Re: DAYCLONA] #959114
05/08/11 09:49 AM
05/08/11 09:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike why would a 70 B body K frame make a difference , it's the same K used in 69 starting sometime in March of 69?
I'm having a hard time believing that others don't have this issue with the Kielser install.
69, have you confirmed that your driveshaft angles are correct now? Nice work , can't wait to see the finished floor tunnel.
Re: Need advice / ideas on trimming torsion bar crossme [Re: 69charger440_6pa] #959115
05/08/11 10:50 AM
05/08/11 10:50 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
So how much did you raise the rear of the tranny? I used a 1" spacer on my Challenger and still have clearance to the crossmember.
One thing I noticed little changes in engine position makes a big difference.
Re: Need advice / ideas on trimming torsion bar crossme [Re: RTSE4ME] #959116
05/08/11 01:05 PM
05/08/11 01:05 PM
Oakley CA
Oakley CA
The tranny is raised up to the factory position of the old 4 speed. I think I have about 2" of spacers from keisler inbetween the tranny and the mounting braket.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
