Cuda Trim Restoration Shop #958810
03/26/11 12:35 AM
03/26/11 12:35 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I have some nice anodized trim pieces from the tail panel on my cuda. Very few dents but they have lots of scratches. Who can recommend someone to restore these and what do they charge?
Thanks Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cuda Trim Restoration Shop [Re: 19cuda73] #958811
03/26/11 03:20 AM
03/26/11 03:20 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
There are only a few shops that can do it correctly. In any case, it will be VERY expensive. I used King of trim in CA with good results before.
Re: Cuda Trim Restoration Shop [Re: Barnabas_Kriss] #958812
03/26/11 02:12 PM
03/26/11 02:12 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Check prices. BE/A has repro that was cheaper than refinishing mine. I am keeping my originals as they are always better than reproductions. Just cannot justify the expense of redoing them at this time and BE/A's look great to me. If your are going to show yours, money redoing the originals will be well spent. If it is a cruise restoration, the reproductions will be fine.
Craig
Re: Cuda Trim Restoration Shop [Re: 19cuda73] #958813
03/26/11 06:02 PM
03/26/11 06:02 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Thanks Dennis
Let me share something with you. You should put them in a plastic tube that doesn't bend or some equivalent. I sent mine out sandwiched between some wood paneling via FedEx to BE&A and they arrived bent.
Re: Cuda Trim Restoration Shop [Re: rayztoy] #958814
03/27/11 12:48 AM
03/27/11 12:48 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
remove 'em.
'72-'74s look better w/o the Gran Coupe trim.
