Weird problem..oil pump regulator?? #958461
03/25/11 01:25 PM
03/25/11 01:25 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I have a 440 that usually runs with 30-35lbs of oil pressure at idle and anything above around 1500rpm the pressure goes right to 80lbs or more.
What's weird is in the last couple of days its now running at 80lbs at idle and 80lbs or a bit more at any rpm above that, hardly any difference in oil pressure across a range of rpm's. I am reading this on a mechanical gauge straight off the rear of the block. I hooked up a spare gauge and its giving me the same exact readings. Very weird.
Could this be an oil pump regulator? Any suggestions?
Thanks,
Wolfe
Re: Weird problem..oil pump regulator?? [Re: Wolfe440] #958462
03/25/11 02:50 PM
03/25/11 02:50 PM
Thanks,
Wolfe
Take the bypass plug and spring out and see if the bypass valve will slide out of the pump cover easily, if it doesn't fix it. It is not unusual for debris to get into the valve and make it stick
Re: Weird problem..oil pump regulator?? [Re: Cab_Burge] #958463
03/25/11 03:04 PM
03/25/11 03:04 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
ok, I will give it a try, thanks.
Re: Weird problem..oil pump regulator?? [Re: Cab_Burge] #958464
03/25/11 07:39 PM
03/25/11 07:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If the oil pressure went from 35 to 80 at idle, it not the spring or relief valve. The relief was not open at 35 to begin with.
Re: Weird problem..oil pump regulator?? [Re: BSB67] #958465
03/25/11 08:13 PM
03/25/11 08:13 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
This doesn't make sense. If it was 35, of course it could have been open. Now that it's high, it could be plugged.
Re: Weird problem..oil pump regulator?? [Re: Yancy Derringer] #958466
03/25/11 08:21 PM
03/25/11 08:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
is your oil filter "Orange" ?
I am truckless..
Re: Weird problem..oil pump regulator?? [Re: Yancy Derringer] #958467
03/25/11 09:32 PM
03/25/11 09:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The only way that works is if the valve didn't close fully possibly due to a burr or something of that sort, otherwise low pressure won't open the valve because the spring pressure is constant... It was lifting @ 80 psi.... If the valve opens at 35 psi the pressure wouldn't rise above 35 psi unless the pump volume was so great it overcomes the flow capacity of the relief passage... Pressure rising typically indicates a place where oil was previously able to leak internally has become sealed... That could indicate a number of causes including plugged rocker feed, a spun bearing, a plugged chain oiler..
Re: Weird problem..oil pump regulator?? [Re: 1_WILD_RT] #958468
03/25/11 09:53 PM
03/25/11 09:53 PM
Montana
Y
Y
Montana
Scuse me you are correct, I was thinkin' basackwards. Yep. low idle pressure indicates the pump cannot keep up with "the leaks" because normally at low pressure the bypass will be closed. Now that it's high, SOMETHING in there has plugged
Re: Weird problem..oil pump regulator?? [Re: 1_WILD_RT] #958469
03/26/11 01:00 AM
03/26/11 01:00 AM
How about a piece of debris wedge into the valve and the pump channel keeping the valve locked closed, like it is when the motor is shut off
Re: Weird problem..oil pump regulator?? [Re: Cab_Burge] #958470
03/26/11 01:05 AM
03/26/11 01:05 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The thing is the reason the pressure is lower at idle is because enough leakage occurs at all the normal internal leak points IE bearings,rockers, lifters & what not that the pump doesn't move enough volume of oil to create enough pressure to lift the relief valve so if the valve was jammed shut the pressure would still only be 35 psi.. But at higher rpm's the pressure could easily see 100+ psi...
Re: Weird problem..oil pump regulator?? [Re: 1_WILD_RT] #958471
03/26/11 03:17 PM
03/26/11 03:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'm thinking possible filter faiure as mentioned earlier.
Re: Weird problem..oil pump regulator?? [Re: stumpy] #958472
03/26/11 03:47 PM
03/26/11 03:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Filter is after the pump.
Re: Weird problem..oil pump regulator?? [Re: NITROUSN] #958473
03/26/11 03:57 PM
03/26/11 03:57 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
It may have a cam bearing spun, I am not getting any oil up to the rockers now. Apparently the feed is blocked and the resistance is what is bringing up the oil pressure. Must dig in more to find out for sure.
Re: Weird problem..oil pump regulator?? [Re: Cab_Burge] #958474
03/26/11 04:15 PM
03/26/11 04:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think you need to read the original post again and think about it
