Re: blower motor not working 02 Dakota
[Re: ekim]
#958403
03/25/11 12:37 PM
03/25/11 12:37 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
99.9 % of the time its the resistor.You cant miss the power wire.Its big and red I believe.I also think the switch actually controls the ground if my memory is correct.Rocky.
Chrysler Firepower
[Re: JonC]
#958407
03/25/11 06:42 PM
03/25/11 06:42 PM
Posts: 21,430 It's a dry heat
gtx6970
It's a dry heat
Isn't usually if it is the resistor it will still work on high??
Not always. I've had more than a few with no speeds at all and it was the resistor.
Run a power and ground wire to the motor and see if it works. If it does put a resistor in it . they are cheap and fix 99.9% of them
If you have blower motor wiring meltdown. You need a blower motor AND a resistor/wiring conector
[Re: therocks]
#958408
03/25/11 07:51 PM
03/25/11 07:51 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Yes, I think the switch controls the ground also. So the blower motor should be "upstream" or ahead of the resistor. If you run a test jumper ground from the motor ground lead, the motor should run for test purposes (or just bypass the resistor with a jumper, temporarily), would be same as running on high speed.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#958409
03/26/11 08:54 AM
03/26/11 08:54 AM
therocks
Niles , Ohio
By the time you go thru all that just get a resistor.Un plug the old one and connect the new one.Blower should work.If not then its probally the motor.Ive only seen 1 bad motor in 10 years.We had parts store next to the shop so it was easier to walk over and get the part.If the plug is melting the motor is probally bad.But like Ive said in over 10 years 1 bad motor.GM had a big problem with the resistors.You dont even need to pull the old one out to test the new one.My buddy that works at dealer does the same thing.Just tries a new resistor.Easy test disconnect plug.Hook light between hot and ground in the plug.The light should light with key on and switch on.Rocky
Chrysler Firepower
