blower motor not working 02 Dakota #958400
03/25/11 09:08 AM
03/25/11 09:08 AM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
It has power at the fuse, any ideas ?
It does not work on any speed.
Re: blower motor not working 02 Dakota [Re: ekim] #958401
03/25/11 09:34 AM
03/25/11 09:34 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
First place to look is at the resistor and it's connector under dash above pass side feet area.
Re: blower motor not working 02 Dakota [Re: buildanother] #958402
03/25/11 09:49 AM
03/25/11 09:49 AM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
Without a wiring diagram all I did was wiggle wires and connections. But I do have a test light if anyone can tell me what color wire should have power and when, I can check it, thanks
Re: blower motor not working 02 Dakota [Re: ekim] #958403
03/25/11 12:37 PM
03/25/11 12:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
99.9 % of the time its the resistor.You cant miss the power wire.Its big and red I believe.I also think the switch actually controls the ground if my memory is correct.Rocky.
Chrysler Firepower
Re: blower motor not working 02 Dakota [Re: therocks] #958404
03/25/11 01:23 PM
03/25/11 01:23 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Isn't usually if it is the resistor it will still work on high??
Re: blower motor not working 02 Dakota [Re: JonC] #958405
03/25/11 01:31 PM
03/25/11 01:31 PM
chicagoland,usa
chicagoland,usa
Not always. That's why you check connector for meltdown damage.
Re: blower motor not working 02 Dakota [Re: buildanother] #958406
03/25/11 03:06 PM
03/25/11 03:06 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
Similar issue on my '88 Dakota; needed a new fan switch.
Re: blower motor not working 02 Dakota [Re: JonC] #958407
03/25/11 06:42 PM
03/25/11 06:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not always. I've had more than a few with no speeds at all and it was the resistor.
Run a power and ground wire to the motor and see if it works. If it does put a resistor in it . they are cheap and fix 99.9% of them
If you have blower motor wiring meltdown. You need a blower motor AND a resistor/wiring conector
Re: blower motor not working 02 Dakota [Re: therocks] #958408
03/25/11 07:51 PM
03/25/11 07:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, I think the switch controls the ground also. So the blower motor should be "upstream" or ahead of the resistor. If you run a test jumper ground from the motor ground lead, the motor should run for test purposes (or just bypass the resistor with a jumper, temporarily), would be same as running on high speed.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: blower motor not working 02 Dakota [Re: GO_Fish] #958409
03/26/11 08:54 AM
03/26/11 08:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
By the time you go thru all that just get a resistor.Un plug the old one and connect the new one.Blower should work.If not then its probally the motor.Ive only seen 1 bad motor in 10 years.We had parts store next to the shop so it was easier to walk over and get the part.If the plug is melting the motor is probally bad.But like Ive said in over 10 years 1 bad motor.GM had a big problem with the resistors.You dont even need to pull the old one out to test the new one.My buddy that works at dealer does the same thing.Just tries a new resistor.Easy test disconnect plug.Hook light between hot and ground in the plug.The light should light with key on and switch on.Rocky
Chrysler Firepower
