Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 77ProStreet] #958249
02/02/12 12:35 PM
02/02/12 12:35 PM
No. cal., sacramento usa
speedy383 Offline
speedy383  Offline
My bad , didnt know you already had Dakota spindles,.cant help with that .
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: speedy383] #958250
06/11/12 12:34 AM
06/11/12 12:34 AM
Central Michigan
abody69 Offline
abody69  Offline
Central Michigan
So....no need to notch the frame when doing a simple axle flip? I'm thinking of doing a mild drop on my '83 stepside. I already have a set of LCA from a 3/4 ton van. Great info here.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: speedy383] #958251
06/11/12 01:24 AM
06/11/12 01:24 AM
SW Missouri
moparmandjh Offline
moparmandjh  Offline
SW Missouri
This is the way it looks with the flipped rear and van lower control arms. I plan on bigger rear rims and tires, sorry about the looks ,had to get it ready to race. Went to Infinion yesterday,ran a couple of 13.50s with tire spin , On the third pass i tore the ring gear out of it,so i will be doing some rear work this week.
Wow, strangely familiar......
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: moparmandjh] #958252
07/10/13 07:12 PM
07/10/13 07:12 PM
WI
68hemiss Offline
68hemiss  Offline
WI
Guys,
I am in the middle of lowering an 87 Dodge shortbed of a friend of mines and I am running into tie rod troubles. I used the Rockauto B100 3300lb LCA and got the steering arms from a 95 van in the junkyard. We also cut 1/2 a coil from the springs. The problem is that the tie rod is VERY close to the strut rod. Does anyone have a better pic of what the correct steering arms look like? The pictures don't really show them very well - I wonder if I have the wrong ones.
Moving the tie rod to the top of the steering arms would solve the clearance problem but I don't want to make a bump steer issue. We also do not have the engine in the truck at this time - getting a 440 ready to swap in place of the old 6 cyl. Any help would be appreciated.
Thanks,
Mark J
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 68hemiss] #958253
07/10/13 08:00 PM
07/10/13 08:00 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
You don't use the van steering arms
The only time you change the steering arms is when you use a pocketed LCA's from a truck
I never disconnected the tie rods when I changed these
Here's pic of mine
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: BulletBob] #958254
07/10/13 08:39 PM
07/10/13 08:39 PM
WI
68hemiss Offline
68hemiss  Offline
WI
Bob,
Maybe I wasn't clear - we did use the Van pocketed LCA like Kevin did. Our tie rods are way closer than yours - The sleeve is maybe maybe 1/2"-1" away from the strut rods. I thought I saw a pic where the Steering arms curved up from the ball joint to where the tie rod attaches - ours curve up and then dip back down before the tie rod - that is why I thought that I might have the wrong steering arms. I will try to get some pics.
Thanks,
Mark J
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 68hemiss] #958255
07/10/13 08:41 PM
07/10/13 08:41 PM
WI
68hemiss Offline
68hemiss  Offline
WI
Bob,
It looks like your outer tie rod attaches from the top of the steering arm - ours attaches from the bottom - difference in steering arm?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 68hemiss] #958256
07/10/13 10:27 PM
07/10/13 10:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He never said you didn't use the van lca's. You Don't use the van steering arm AT ALL. His stock one is what's to be used
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 68hemiss] #958257
07/11/13 01:34 AM
07/11/13 01:34 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I used the Rockauto B100 3300lb LCA and got the steering arms from a 95 van in the junkyard. We also cut 1/2 a coil from the springs. The problem is that the tie rod is VERY close to the strut rod. Does anyone have a better pic of what the correct steering arms look like? Any help would be appreciated.
Thanks,
Mark J
You do not use steering arms from any van when you use van LCA's
Reread Kevin's thread, He didn't use van steering arms
Reread my reply I never disconnected the tie rods & didn't until months after the pic when I put all new tie rods, center link & pitman arm on it.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 68hemiss] #958258
08/14/13 02:49 AM
08/14/13 02:49 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
... Does anyone have a better pic of what the correct steering arms look like? ...
Surely somewhere in the 6 pages of this thread there's a pic of my dropped spindles next to dropped Dak spindles and stock spindles. I'm pretty sure they all had arms on them in the pic.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Cheeto] #958259
08/14/13 08:45 AM
08/14/13 08:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Pretty sure that's in Rumblebees write up object them being installed on his 73
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 76dodgeboy] #958260
08/18/13 01:24 AM
08/18/13 01:24 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Hmmm, am I getting old enough that I'm confusing threads? Naw, that can't be.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Cheeto] #958261
08/18/13 10:20 AM
08/18/13 10:20 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I wasn't a member when you built your truck. But its your pic that's posted in his thread
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #958262
02/05/15 12:55 AM
02/05/15 12:55 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Hugh Jorgan] #958263
02/08/15 04:36 PM
02/08/15 04:36 PM
Tipp City, Ohio
Backfire Offline
Backfire  Offline
Tipp City, Ohio
correct me if I'm wrong, but doesn't cutting coils have the same effect as installing van LCA's ?
except that you have a slight increase in spring rate with cut coils .
I cut the coils on my '89 D100 and have no issues with bump steer or parts interfering.
One benefit of both types of lowering that hasn't been mentioned is an improvement in roll center which improves handling. One thing I do want to change on my truck is to put a stiffer shock on the front.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Hugh Jorgan] #958264
02/11/15 12:29 PM
02/11/15 12:29 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
he guys im looking for help, im trying to lower my 3/4 ton crew cab. it has the heavy duty front end on it with pocket lower control arms. any advice other than chopping springs?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: wyldebill] #958265
02/11/15 01:29 PM
02/11/15 01:29 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its cut the springs or install 1/2-3/4 ton springs or have custom made ones or Bags. Or if your feeling real froggy Z the frame or Body drop it
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: 76dodgeboy] #958266
03/13/15 10:38 PM
03/13/15 10:38 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: MattW] #958267
03/15/15 05:03 AM
03/15/15 05:03 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
This thread needs to be a "sticky"!
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #1809100
04/22/15 12:03 AM
04/22/15 12:03 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I'll add to this thread that we found we couldn't use a factory sway bar, frame brackets, and end links (that clamp to the strut rod) with the van lower control arms we installed to lower the truck. The end links interfere with the leading edge of the van control arms since they are so much wider.
Below is a pic of the arm comparison by the OP..
