I used the Rockauto B100 3300lb LCA and got the steering arms from a 95 van in the junkyard. We also cut 1/2 a coil from the springs. The problem is that the tie rod is VERY close to the strut rod. Does anyone have a better pic of what the correct steering arms look like? Any help would be appreciated. Thanks, Mark J
You do not use steering arms from any van when you use van LCA's
Reread Kevin's thread, He didn't use van steering arms Reread my reply I never disconnected the tie rods & didn't until months after the pic when I put all new tie rods, center link & pitman arm on it.
