Abody Upper control arm interchangability ? #957807
03/24/11 05:18 PM
03/24/11 05:18 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
I know A-bodies through 72 had the small upper ball joint, and were small bolt pattern.
What I need to know(for a friend) is on the 73-up A-bodies, I know the disk cars were LBP and had the larger upper ball joint, But do the sbp drum brake cars still have the larger upper ball joint ? Or the small ball joint ?
Re: Abody Upper control arm interchangability ? [Re: MileHighDart] #957808
03/24/11 05:22 PM
03/24/11 05:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I THINK i read that they have the large joint , easy to figure out , go to rock auto and check the 2 years .
I just looked , they only list one balljoint in 73 , it's the bigger one .
Re: Abody Upper control arm interchangability ? [Re: JohnRR] #957809
03/24/11 07:01 PM
03/24/11 07:01 PM
Lyons, CO
Lyons, CO
Thanks JohnRR thats what needed to know.
Re: Abody Upper control arm interchangability ? [Re: MileHighDart] #957810
03/24/11 07:07 PM
03/24/11 07:07 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have a 73 dart swinger that came with a 198 and 4 wheel 10" drums with small ball joints. I had to change to the large ball joint when I went to '73+ style discs.
Re: Abody Upper control arm interchangability ? [Re: radar] #957811
03/24/11 07:11 PM
03/24/11 07:11 PM
Wondering that myself if SBP 4 wheel drums kept the small UBJ thru '76
Re: Abody Upper control arm interchangability ? [Re: radar] #957812
03/24/11 07:34 PM
03/24/11 07:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good to know , I'll have to look at rockauto again , I either missed it or their listing is incorrect, which wouldn't surprise me .
I THINK Dr. Diff sells a spacer that goes on the ball joint stud so you don't have to change control arms ????
Re: Abody Upper control arm interchangability ? [Re: JohnRR] #957813
03/24/11 10:21 PM
03/24/11 10:21 PM
moparx Offline
moparx  Offline
that is correct john. i got a set and they work great !
Re: Abody Upper control arm interchangability ? [Re: moparx] #957814
03/25/11 12:14 AM
03/25/11 12:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This topic got heated last year when a few guys sweared that they had NEVER seen a drum brake 74-76 A body car. I have seen plenty and even owned a few.
The last one was a 73 Dart Sport with a dead slant sick. It had 10" front drums (Finned) and 9 inch rear drums. It had the large ball joint upper control arm. The 9 " front drum cars retained the small ball joint design. ALL the 4 wheel drum A body cars had the small bolt circle.
Stores like Kragen/Advance/O'Rielly and even Rock Auto can have mistakes in their books/computers. I have argued with parts counter guys on several occasions about parts that were on my cars since they were built. Even Ma Mopar screwed up every now and then.
Re: Abody Upper control arm interchangability ? [Re: moparx] #957815
03/25/11 02:10 AM
03/25/11 02:10 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
There were likely some 73 cars that got what was left behind of the SBP, SBJ set ups. I had one as well.
Most all 73+ cars should have the large ball joint regardless of brakes.
Re: Abody Upper control arm interchangability ? [Re: RobX4406] #957816
03/25/11 02:50 AM
03/25/11 02:50 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
ONCE AGAIN...
I have witnessed in wrecking yards AND owned several 73 and later A bodies with 9 inch front drum brakes, small upper ball joint control arms and small bolt pattern. Some contend that they dont exist. I say that if the factory didnt build the cars this way, then several cars that I have seen were DOWNgraded by someone afterwards. Why would so many people switch to SMALLER front brakes? Highly unlikely.
Re: Abody Upper control arm interchangability ? [Re: Kern Dog] #957817
03/25/11 10:25 AM
03/25/11 10:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ONCE AGAIN...
pppsssstttt ... Did you miss this before you flew off the handle as the DEFINITIVE source ???
He didn't say never say never. I can see this being the case with the 9" drum/SBP cars , why make a new spindle for the bigger joint , not that many cars had that brake setup so just use up whatever they had for stock, I'm sure when it was down to a certian level , must have some replacement stock on hand to service cars on the road , no more 9" brake cars with SBP were built.
Re: Abody Upper control arm interchangability ? [Re: MileHighDart] #957818
03/25/11 10:33 AM
03/25/11 10:33 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
My 75 Dart Sport 6cly 3spd had the small joints and bc. All original drum car.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Abody Upper control arm interchangability ? [Re: JohnRR] #957819
03/25/11 01:04 PM
03/25/11 01:04 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Definitive source? Ahhh, you give me too much credit!
I can give you some background, if you care to read on....
In 1995-2000 I was working on a pet project/home video. The topic was a sorta ripoff of the Dukes of Hazzard, The Fall Guy and my own life mixed into one. In the feature, I bought and wrecked several cars doing the various stunts that were filmed including the 15 car jumps. I used up several K frames, control arms and wheels. To keep the cars moving, I frequented the self service yards alot and observed every A body in the 9 Northern California Pick n Pull yards. Even after finishing that project I continued working on A body cars, buying cheap, fixing and selling. I've got some for free, others I have overpaid. I dont claim to be the foremost expert, but I have seen enough of these cars to form a fair assessment. The latest car I owned with 9" drums was a 76 Dart 2 door. I dont remember the exact build date. Its possible that at some point, one of the previous owners pulled the bigger brakes from the car IF IT ORIGINALLY had them, then swapped in the smaller setup just to make the car a roller, but I'll never know. It all was dingy and caked with grease to the point that it looked original.
Re: Abody Upper control arm interchangability ? [Re: JohnRR] #957820
03/25/11 02:05 PM
03/25/11 02:05 PM
RobX4406 Offline
RobX4406  Offline
ONCE AGAIN...
John, this is the best way to handle this situation!
*** You are ignoring this user ***
Re: Abody Upper control arm interchangability ? [Re: RobX4406] #957821
03/25/11 02:27 PM
03/25/11 02:27 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I have a '75 Duster with sbp drums. They do exist. Dad has '74 Dart with the same setup as well.
Re: Abody Upper control arm interchangability ? [Re: DusterKrazy] #957822
03/25/11 02:38 PM
03/25/11 02:38 PM
RobX4406 Offline
RobX4406  Offline
I don't think anybody has said SBP drums weren't around after 72. In fact, the dealer books show /6 cars with drum brakes all the way though production in 1976. Parts books have the drums in them as well.
The federal mandate on disc brakes I believe was only on V8 equipped cars.
The vast majority of 73-76 cars have the big ball joint, PERIOD! There may have been some 9" brake cars that had small ball joint and they are the freak show part of the answer. Per the dealer info, the 9" brakes were supposed to be gone after 1973, 1974 and up, /6 A-bodies should have 10" brakes.
Easy enough to look at the castle nut to determine if it's small or large ball joint. ~5/8 = SBJ, ~13/16 = BBJ.
I'm sure more pontificating will follow.
Re: Abody Upper control arm interchangability ? [Re: MileHighDart] #957823
03/25/11 02:46 PM
03/25/11 02:46 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I just gotta know...what rims are those
Re: Abody Upper control arm interchangability ? [Re: DusterKrazy] #957824
03/25/11 03:15 PM
03/25/11 03:15 PM
Lyons, CO
Lyons, CO
They are REV Wheels (Revolution) Classic 100's They are made by REV, but liscensed by American racing.
Fronts are 15x6 with 205/60/15 and Rears are 15x7 with 225/60/15.
The wheels in my signature pic are photochopped on the car. But as of yesterday they are actually on my car and I'm totally stoked about the way they look.
Heres a pic with them actually on the car.
Re: Abody Upper control arm interchangability ? [Re: MileHighDart] #957825
03/25/11 03:21 PM
03/25/11 03:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
large pattern or small ???
Re: Abody Upper control arm interchangability ? [Re: RobX4406] #957826
03/25/11 03:22 PM
03/25/11 03:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is Pontificator a word ???
