Is it possible to move a tail panel stripe? #957345
03/23/11 10:49 PM
03/23/11 10:49 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Years ago my Demon tail panel stripe was placed too low. Is it possible to move it? How? Thanks
Still looking for LM29H1B415501, '71 Demon 340
Re: Is it possible to move a tail panel stripe? [Re: PAULS_340] #957346
03/23/11 11:07 PM
03/23/11 11:07 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Good Lookin Demon! I always liked YELLOW! I don't know to much about the stripes on a Demon but it looks like the trunk key cylinder is centered in the top part of the stripe. If you were to raise it would that be correct? At any rate I think your into it another stripe, I don't think you can remove it and reuse it now.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Is it possible to move a tail panel stripe? [Re: U code RR] #957347
03/23/11 11:20 PM
03/23/11 11:20 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A heatgun or hairdryer can be used to loosen the adhesive up enough to pull it off.
I don't see how it could be removed without stretching the vinyl so I'd just order up a new one. Even if you could get it off without wrecking it I doubt it would stick as well going on the 2nd time.
Re: Is it possible to move a tail panel stripe? [Re: Neil] #957348
03/24/11 10:58 AM
03/24/11 10:58 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
nice demon,hair dryer,plus patients,but you are buying a new stripe,second option,it probably bothers you more,doubt most even notice
Re: Is it possible to move a tail panel stripe? [Re: PAULS_340] #957349
03/24/11 11:22 AM
03/24/11 11:22 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Last demon stripe kit I got was 2 pieces. Your existing upper piece looks correct, but the lower piece should have been raised up for proper spacing around tailight etc. I've seen the 2 piece kit installed with the end tabs butted together, and then stripes don't end up close enough to taillights and looks silly.
Re: Is it possible to move a tail panel stripe? [Re: PAULS_340] #957350
03/24/11 05:51 PM
03/24/11 05:51 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
No you cannot move/save the old one.
