coil bind and valve seal clearance #957019
03/23/11 02:00 PM
03/23/11 02:00 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
What is safe on a small block? I know what my spings have coil bind a .600 and I am planning on .550. Is that too close? I have enought seal/ratiner clearance to go .700.. That shouldnt be a problem.
Re: coil bind and valve seal clearance [Re: mopfried] #957020
03/23/11 04:20 PM
03/23/11 04:20 PM
On all of the good race springs the manufacturers recommend no closer than .060 to coil bind I check every spring on that every time
Re: coil bind and valve seal clearance [Re: mopfried] #957021
03/23/11 05:15 PM
03/23/11 05:15 PM
Alot of rockers dont have a true 1.5 so when you mockup & check actual you may b good as is but yes you're getting close
