"Banana grooving" rocker shafts #957011
03/23/11 01:57 PM
03/23/11 01:57 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Recently picked up a set of Crane ductile iron adjustable rockers (small block).
Wondering if it is necessary to "banana groove" the oiling holes in the shafts.
If so, what is the preferred technique to put in the grooves?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: "Banana grooving" rocker shafts [Re: 471Magnum] #957012
03/23/11 02:00 PM
03/23/11 02:00 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There's a rocker arm shop in Washington state that repairs, blueprints and upgrades rocker arms. Someone here probably has their information. They might be good ones to ask.
Re: "Banana grooving" rocker shafts [Re: jbc426] #957013
03/23/11 02:04 PM
03/23/11 02:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
RAS is the company , doing the grooving for that rocker would not be a bad idea.
edit for fat fingers
Re: "Banana grooving" rocker shafts [Re: JohnRR] #957014
03/23/11 02:45 PM
03/23/11 02:45 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
RHS is the company , doing the grooving for that rocker would not be a bad idea.
i think you mean RAS - Rocker Arm Specialties
Re: "Banana grooving" rocker shafts [Re: DJVCuda] #957015
03/23/11 02:50 PM
03/23/11 02:50 PM
Space Station #5
Space Station #5
Is it really that difficult that I couldn't just feather out the holes with a pencil-tipped grinder? I've got a couple of old shafts I can practice on.
-Jim
Re: "Banana grooving" rocker shafts [Re: 471Magnum] #957016
03/23/11 03:01 PM
03/23/11 03:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
what is "banana grooves" ?
Re: "Banana grooving" rocker shafts [Re: NachoRT74] #957017
03/23/11 05:20 PM
03/23/11 05:20 PM
Nacho those are slits across the oiling holes that HP shafts have. Just create your own w a hacksaw blade & deburr the edges that the blade kicks up and as said make the hole a bit wider
Re: "Banana grooving" rocker shafts [Re: 471Magnum] #957018
03/23/11 06:03 PM
03/23/11 06:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that's how I would do it , just don't get to carried away , measure the rocker width and mark the shaft with a marker , I can dig out a shaft and measure how wide the grooves are ...
