A friend of mine built a pump-gas 408 stroker for my Duster
pretty happy with the results
Basic Combo:
Mancini forged Eagle crank 360 internally balanced stroker kit
RHS/Indy iron X-heads - prepped by IMM engines, (basic $1395.00 package - see info at
http://www.immengines.com/rhsheads.html )
compression 10:1
Hughes solid cam - sorry not 100% positive which one - I think it's HUG HTL4852AS (Intake .563/Exh .572 w 1.5 ratio, 248/252 duration)
old mopar iron rockers
Proform/Holley 750 carb - with 1" super sucker spacer
MP performance disti - locked at 37.5 degrees
Kevco 6qt pan, Holley strip dominator single plane intake
91 octane pump gas
best run - 503hp @5500, 520lbs @4700
