Dyno'd my new 408 #956987
03/23/11 01:52 PM
03/23/11 01:52 PM
Eau Claire, WI
Charger727 Offline OP
Eau Claire, WI
A friend of mine built a pump-gas 408 stroker for my Duster
pretty happy with the results
Basic Combo:
Mancini forged Eagle crank 360 internally balanced stroker kit
RHS/Indy iron X-heads - prepped by IMM engines, (basic $1395.00 package - see info at http://www.immengines.com/rhsheads.html )
compression 10:1
Hughes solid cam - sorry not 100% positive which one - I think it's HUG HTL4852AS (Intake .563/Exh .572 w 1.5 ratio, 248/252 duration)
old mopar iron rockers
Proform/Holley 750 carb - with 1" super sucker spacer
MP performance disti - locked at 37.5 degrees
Kevco 6qt pan, Holley strip dominator single plane intake
91 octane pump gas
best run - 503hp @5500, 520lbs @4700
Re: Dyno'd my new 408 [Re: Charger727] #956988
03/23/11 02:03 PM
03/23/11 02:03 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
That's about what my 408 did. But I have hydraulic cam (248/254) and 1.6 ratio arms, .600 lift. Compression is 10.2:1 ported Eddy heads. M1 intake, but no spacer, same carb. All in all, very similar builds except the actual heads. My heads flowed 284cfm. Do you know what yours flowed? I could have pushed my compression higher to get more out of my aluminum heads, but I didn't. My best hp was at 5800 and best tq was at 4700 - pretty much the same as yours... built for the street.
You probably spent less than me, so you should feel good!
Re: Dyno'd my new 408 [Re: PAINT IT BLACK] #956989
03/23/11 10:22 PM
03/23/11 10:22 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Sounds like a nice little motor. What RPM does the motor like to idle at with that much cam?
Re: Dyno'd my new 408 [Re: Charger727] #956990
03/24/11 10:00 AM
03/24/11 10:00 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That works good!
Re: Dyno'd my new 408 [Re: Darryls-Demon] #956991
03/24/11 10:18 AM
03/24/11 10:18 AM
Eau Claire, WI
Eau Claire, WI
Not sure about that, I had a 416 with an even hotter cam and it had to idle at 1100-1200
I suspect this one will be a bit lower - bolting it to a 4-speed
Re: Dyno'd my new 408 [Re: Charger727] #956992
03/24/11 10:27 AM
03/24/11 10:27 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Sweet!
That's right in the range that I'd like to do for a fun street/strip motor for my 80 Cordoba LS.
Re: Dyno'd my new 408 [Re: Dean_Kuzluzski] #956993
03/24/11 02:24 PM
03/24/11 02:24 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Sweet.
I've got a 410 project on the engine stand right now. Wish the budget would accommodate those RHS heads, but I'll be running some J-heads for now. My expectations are a bit more modest, but I'm sure it will turn the tires better than the stock 72 340 ever could.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Dyno'd my new 408 [Re: 471Magnum] #956994
03/24/11 04:37 PM
03/24/11 04:37 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Awesome! Those numbers give me some real inspiration towards my roller 408 project.
