Cam upgrade recommendations.......Nobody else?? #956794
03/23/11 09:33 AM
03/23/11 09:33 AM
New York
R/T1968R/T Offline OP
New York
Right now Im running a Comp Hydraulic XE 275HL in a 440 with Speedpro 2355 pistons (9.7 comp) and HP exhaust. I used this cam because of the restrictions in the exhaust.The car ran mid 12s through the mufflers with this combo and a 3200 stall convertor and 3.91s. Im putting the 2 inch Proparts headers on the car now so it can breath. I want to go mechanical. The motor has Mopar 1.6 roller rockers on it. I was thinking of the .557 MP or the Racer Brown ST-21. Any thoughts??
Re: Cam upgrade recommendations [Re: R/T1968R/T] #956795
03/23/11 09:54 AM
03/23/11 09:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
with the 1.6's the 557 will be 594 lift minus the lash. Should work good I would think. You'd probably be smart to check and see if you have enough spring pressure for that. With a good tune you might be knocking on the 10's I'd think.
Coming soon!!!!
Re: Cam upgrade recommendations.......Nobody else?? [Re: R/T1968R/T] #956796
03/23/11 06:13 PM
03/23/11 06:13 PM
New York
New York
No one else has an idea?
Re: Cam upgrade recommendations.......Nobody else?? [Re: R/T1968R/T] #956797
03/23/11 08:36 PM
03/23/11 08:36 PM
Washington, Pa
runner12 Offline
runner12  Offline
Washington, Pa
Ihave had great luck with all the products from HUGHES ENGINES and all they do is MOPAR....call Dave!
Re: Cam upgrade recommendations.......Nobody else?? [Re: R/T1968R/T] #956798
03/24/11 03:55 AM
03/24/11 03:55 AM
I've use the XE285HL and the XE295Hl in two different motors in my Duster, it ran 11:30s spinning the tires through the muffs and pump gas motor only with the 446 C.I. motor with the XE285HL cam.That motor is 9.46 to 1 comp ratio using the Speed Pro forged six pak pistons and a set of ported 906 heads with 2.14 and 1.81 valves, Eddy RPM intake and a Holley 950 HP The other motor is a 464 C.I., 4.35 bore with a offset ground 440 crank with 3.91 stroke, Diamond custom pistons, 10.46 to 1 comp. ratio, Eddy RPM heads unported and a stock Eddy six pak intake and stock vacume carbs work on, that combination runs high tens with the muffs and air cleaner on motor only on pump gas.BTW, I hate Mopar cams, all of them I have built and raced Mopars for a lot of years, my low deck stroker 518 C.I. pump gas motor runs low tens with a set of ported Eddy RPM heads and a low deck six pak, Comp Cams custom grind solid roller that is 260 @ .050 intake side,266 @ .050 exhaust with right at .700 net lift at the retainers using a set of Harland Sharp 1.6 rockers in my 3450 Lb Duster on M/T ET Street Radials Lots of ways to go, especially on cam selections. BTW I have a freind who used the Comp Cams XS290S in a street pump gas 496 C.I.stroker motor in a 1968 Charger with 3.23 and a 727, it is his wifes car and it runs mid elevens corked up IHTH
Re: Cam upgrade recommendations [Re: Mr.Yuck] #956799
03/24/11 09:13 AM
03/24/11 09:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 557 mopar cam should be a good fit for your combo.
Re: Cam upgrade recommendations [Re: DaytonaTurbo] #956800
03/24/11 01:32 PM
03/24/11 01:32 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've been happy with my Racer Brown cams. Give Jim a call and tell him what you want to do.
Re: Cam upgrade recommendations [Re: bobby66] #956801
03/24/11 02:35 PM
03/24/11 02:35 PM
Is he still in business? I thought he closed up several years ago do to the sagging economy
Re: Cam upgrade recommendations.......Nobody else?? [Re: R/T1968R/T] #956802
03/24/11 02:50 PM
03/24/11 02:50 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Call Dwayne Porter (PRH, Vermont) and give him ALL the info on your combination. He'll spec & supply a custom COMP Cams grind for you and can assist you w/ making sure you have the correct hardware (springs, etc.) to go w/ it.
You can get his phone # off his user link for "fast68plymouth". I should have it memorized by now, but I guess that's the price of getting old...
