ever tried Adjust-a-jet on ur carb? #956547
03/22/11 07:16 PM
03/22/11 07:16 PM
colorado
1badD50 Offline OP
1badD50  Offline OP
colorado
was wondering if anybody's tried using an adjust-a-jet on your holley or demon? seems kinda cool idea but i've never seen them before just looking for some feed back
Re: ever tried Adjust-a-jet on ur carb? [Re: 1badD50] #956548
03/23/11 02:58 PM
03/23/11 02:58 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Bump! I'm also interested in any real world experience.
Percy's Adjust a Jet, correct?
Re: ever tried Adjust-a-jet on ur carb? [Re: gsmopar] #956549
03/23/11 06:23 PM
03/23/11 06:23 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i have one of those on my 650 db pumper.it was used on my 340 and my 318,ive had it at least 10-12yrs now,had to remove the jets,add the plate,have to use there longer accelerator pump arm.keep in mind u also have to change the length of the fuel line, due to the distance between the fuel bowls being longer with this plate installed,thats only thing i remember running into with this kit.u can adjust the screw setting for more or less fuel,even with it idling,always worked good for me.they send a sheet with it for ball park jet settings.mike
Re: ever tried Adjust-a-jet on ur carb? [Re: hp340nos] #956550
03/23/11 08:16 PM
03/23/11 08:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've always wanted to try these but that's the first good thing I've ever heard about them^^^^^^
Re: ever tried Adjust-a-jet on ur carb? [Re: ProSport] #956551
03/23/11 09:34 PM
03/23/11 09:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
They look like they would be a nice toy, but once you have your jetting dialed in, you usually leave it alone, so after that point the adjust-a-jet would be kinda pointless.
Re: ever tried Adjust-a-jet on ur carb? [Re: DaytonaTurbo] #956552
03/23/11 09:51 PM
03/23/11 09:51 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Never used
One but I guess they will still come Into play
For altitude
Corrections...
Mopar Performance
Re: ever tried Adjust-a-jet on ur carb? [Re: moparniac] #956553
03/23/11 10:29 PM
03/23/11 10:29 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i only re-adjusted mine on real cool nights (50*) at the track,i moved it one mark on the metering block which was roughly 2-3 jet sizes more fuel.
Re: ever tried Adjust-a-jet on ur carb? [Re: hp340nos] #956554
03/23/11 10:40 PM
03/23/11 10:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Many, many moons ago I used them on my VolksWagon Beetles after I put hedders on them. They helped a little.
Master, again and still
Re: ever tried Adjust-a-jet on ur carb? [Re: DaveRS23] #956555
03/23/11 10:49 PM
03/23/11 10:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've got a pair in my carb box; I used them years ago for a couple of track days until I decided to just settle on a jet size. I think they could be a good idea if you were changing elevations and were running things a bit lean.
Re: ever tried Adjust-a-jet on ur carb? [Re: topside] #956556
03/24/11 12:34 AM
03/24/11 12:34 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i used to run one on my old 750 dp holley. at the time i thought it was a handy thing to have. my current 4150 series Demon has had the same jets in it for the past 4 years, maybe if i was looking for a record i'd change them but i'm only bracket racing so they seem just fine for my application.
Re: ever tried Adjust-a-jet on ur carb? [Re: DaytonaTurbo] #956557
03/24/11 12:37 AM
03/24/11 12:37 AM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
IbadD50's home track is 4500+ ft elevation and corrected is usually 5500+ on good days, so most of the tracks he travels to are much lower corrected(or uncorrected)and much better air...so its really not pointless!
Re: ever tried Adjust-a-jet on ur carb? [Re: SuperStockWagon] #956558
03/24/11 01:19 AM
03/24/11 01:19 AM
Escondido, CA
64physhy Offline
64physhy  Offline
Escondido, CA
I had a set I was going to use on a Proform carb I had. They wouldn't fit the proform metering blocks. I have a holley HP now, but decided on a jet size and sold the adjust a jets.
Re: ever tried Adjust-a-jet on ur carb? [Re: 64physhy] #956559
03/24/11 10:31 AM
03/24/11 10:31 AM
colorado
1badD50 Offline OP
1badD50  Offline OP
colorado
well thanks for all the input guys, I'm thinking they are worth a shot, It just seems it would give you more tune-ability, just my two
Re: ever tried Adjust-a-jet on ur carb? [Re: 1badD50] #956560
03/25/11 10:36 AM
03/25/11 10:36 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
"In concept" I think it's a cool deal. What I'd like to know is how precision the jetting adjustments are in reality. And unless there are some "fixed" increments of adjustments to ensure consistent changes, it sounds kind of hit-or-miss to me to duplicate the settings.
