741 case with 3:91 how noisy? #956280
03/22/11 12:37 PM
03/22/11 12:37 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
A friend has a 741 case with sure grip 3:91 gears he wants to trade. He said at highway speed they are noisy. I haven't heard them as they are already out of his car. Should 3:91's have any noise at all or is this normal. He said he had them checked and they were set properly. I have 3:23's right now and they are very quiet. Do you think there should be any concern?
Thanks everyone, Russ:)
BigBlock 74 Swinger
Re: 741 case with 3:91 how noisy? [Re: bb74swngr] #956281
03/22/11 01:14 PM
03/22/11 01:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
A good gearset is quiet. Worn gears can/will be noisey. Poorly setup or improperly broken in performance ratios may also be noisey. If it's noisey, it's not fatal. But I'd want to ride in the car, inspect the teeth and run a pattern on it before I took it in trade.
Re: 741 case with 3:91 how noisy? [Re: bb74swngr] #956282
03/22/11 04:05 PM
03/22/11 04:05 PM
Dont trade him as it'll get on your nerves the same as they are on his . The power lock sure grip out of it would b worth something to part it out
Re: 741 case with 3:91 how noisy? [Re: RapidRobert] #956283
03/22/11 04:19 PM
03/22/11 04:19 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Youz guyz ... YOU want to hear NOISEY ? ... throw in a 5.57 pig
ONLY way yu can drown-that-out is to OPEN UP the headers
Re: 741 case with 3:91 how noisy? [Re: dOrk !] #956284
03/22/11 05:16 PM
03/22/11 05:16 PM
P
Paul_Fancsali Offline
P
I have had 3.91s in 741 case set upn and all new bearings and there is still some noise that is ring and pinion related. I have a set 4.30s and 4.56s in 489 cases and they are quiet. I'm convinced once they have a pattern set you will never get rid of all the noise. I can say the noise is ther but they have survived so far 1 year and several dozen hard passes with M&H's.
Re: 741 case with 3:91 how noisy? [Re: Paul_Fancsali] #956285
03/22/11 06:01 PM
03/22/11 06:01 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks Dave, Robert, Eric, and Paul. I appreciate your expertise and understand I need to be careful. I think I will ask to drop them in and take it for a spin before I agree to the swap...and listen closely, check the pattern:)
Points to ponder...thanks all,
Russ:)
BigBlock 74 Swinger
Re: 741 case with 3:91 how noisy? [Re: bb74swngr] #956286
03/22/11 06:46 PM
03/22/11 06:46 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a 741 case 3.91 and it is very quiet.
I've got a 489 4.56's on a spool that sound like the car has a GMC blower on it.
