741 case with 3:91 how noisy?
#956280
03/22/11 12:37 PM
03/22/11 12:37 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
A friend has a 741 case with sure grip 3:91 gears he wants to trade. He said at highway speed they are noisy. I haven't heard them as they are already out of his car. Should 3:91's have any noise at all or is this normal. He said he had them checked and they were set properly. I have 3:23's right now and they are very quiet. Do you think there should be any concern? Thanks everyone, Russ:)
BigBlock 74 Swinger
Re: 741 case with 3:91 how noisy?
[Re: bb74swngr]
#956281
03/22/11 01:14 PM
03/22/11 01:14 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
A good gearset is quiet. Worn gears can/will be noisey. Poorly setup or improperly broken in performance ratios may also be noisey. If it's noisey, it's not fatal. But I'd want to ride in the car, inspect the teeth and run a pattern on it before I took it in trade.
[Re: Paul_Fancsali]
#956285
03/22/11 06:01 PM
03/22/11 06:01 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks Dave, Robert, Eric, and Paul. I appreciate your expertise and understand I need to be careful. I think I will ask to drop them in and take it for a spin before I agree to the swap...and listen closely, check the pattern:) Points to ponder...thanks all, Russ:)
BigBlock 74 Swinger
[Re: bb74swngr]
#956286
03/22/11 06:46 PM
03/22/11 06:46 PM
Posts: 20,166 Park Forest, IL
slantzilla
Park Forest, IL
I have a 741 case 3.91 and it is very quiet. I've got a 489 4.56's on a spool that sound like the car has a GMC blower on it.
