Help, need an ignition switch. Cant find one. #955988
03/21/11 10:05 PM
03/21/11 10:05 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I am working on a 1993 Dodge W250, with a tilt column.
I need to replace this part: 432623199
I have tried NAPA, Rock Auto, and other local parts stores. No one has this thing.
Rock Auto has something close, but its listed for a non-tilt column.
Any leads, or help would be really great.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955989
03/21/11 10:07 PM
03/21/11 10:07 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Just to be clear, I DO NOT need the lock cylinder, that is readily available.
I need the actual ignition switch which mounts behind the column covers, and the lock cylinder fits into.
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955990
03/21/11 10:09 PM
03/21/11 10:09 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
How about the local Dodge dealer? Sometimes you just got to bite the expensive bullet.
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955991
03/21/11 10:10 PM
03/21/11 10:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Which part do you need? Switch or the key lock cyl? The number looks wrong. I am pretty sure on that style column the tilt and non tilt take the same parts.
Re: Help, need an ignition switch. Cant find one. [Re: NITROUSN] #955992
03/21/11 10:26 PM
03/21/11 10:26 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I need the switch, not the cylinder. (I cover that in the second post)
I need the part the harness plugs into.
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955993
03/21/11 10:28 PM
03/21/11 10:28 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
the part on the switch is in two tiers.
First is:
4326
then:
23199
And just to the left of those is:
622 (the 6 being in small text, and the 22 in large text)
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955994
03/21/11 10:43 PM
03/21/11 10:43 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I am pretty sure the standard us240 or the airtex 1s6275 will work. When they went to that style column tilt or non tilt truck or car most parts interchange.
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955995
03/21/11 10:46 PM
03/21/11 10:46 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Help, need an ignition switch. Cant find one. [Re: NITROUSN] #955996
03/21/11 10:48 PM
03/21/11 10:48 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
OK thanks for the info. I will try one.
Rock Auto did have a listing for a tilt column switch, but it was the kind that mounts at the bottom of the column.
Re: Help, need an ignition switch. Cant find one. [Re: OzHemi] #955997
03/21/11 10:54 PM
03/21/11 10:54 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
http://www.amazon.com/Borg-Warner-CS590-...3&carId=007
For tilt steering...
Unfortunately that is the wrong one, it looks like this:
http://shop.advanceautoparts.com/webapp/...673-_-10711125#
Im not sure where that mounts, but its nowhere on my column.
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955998
03/21/11 10:57 PM
03/21/11 10:57 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Bummer
Re: Help, need an ignition switch. Cant find one. [Re: hp383] #955999
03/21/11 11:03 PM
03/21/11 11:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most aftermarket listings are screwed up. I would call a dealer and get the oem number and see what it crosses to.
Re: Help, need an ignition switch. Cant find one. [Re: NITROUSN] #956000
03/22/11 12:21 AM
03/22/11 12:21 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That looks exactly like the one for my wife's 95 LeBaron (found at Kragen/O'Rielly's) and the 96 Dakota we parted out.......
Re: Help, need an ignition switch. Cant find one. [Re: Jim_Lusk] #956001
03/22/11 01:27 AM
03/22/11 01:27 AM
Under My Car
Mopar_Country Offline
Under My Car
You might try this place, you will have to call them tomorrow.
http://www.arizonaparts.com/
Re: Help, need an ignition switch. Cant find one. [Re: Mopar_Country] #956002
03/22/11 08:06 PM
03/22/11 08:06 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
I just replaced mine last fall, (93 W250 w/tilt), got it at the local parts store. I think it was Standard part line, will have to look for the receipt for the p/n though, the parts store is closed when I'm off work. The local used to be dodge dealer gave me the p/n for the local guys' stock since it's n/a from dodge.
Mike
