Help, need an ignition switch. Cant find one.
#955988
03/21/11 10:05 PM
03/21/11 10:05 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am working on a 1993 Dodge W250, with a tilt column.
I need to replace this part: 432623199
I have tried NAPA, Rock Auto, and other local parts stores. No one has this thing.
Rock Auto has something close, but its listed for a non-tilt column.
Any leads, or help would be really great.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Help, need an ignition switch. Cant find one.
[Re: hp383]
#955989
03/21/11 10:07 PM
03/21/11 10:07 PM
hp383
State of Confusion
Just to be clear, I DO NOT need the lock cylinder, that is readily available.
I need the actual ignition switch which mounts behind the column covers, and the lock cylinder fits into.
[Re: NITROUSN]
#955992
03/21/11 10:26 PM
03/21/11 10:26 PM
hp383
State of Confusion
I need the switch, not the cylinder. (I cover that in the second post) I need the part the harness plugs into.
[Re: hp383]
#955993
03/21/11 10:28 PM
03/21/11 10:28 PM
hp383
State of Confusion
the part on the switch is in two tiers.
First is: 4326
then: 23199
And just to the left of those is: 622 (the 6 being in small text, and the 22 in large text)
[Re: NITROUSN]
#955996
03/21/11 10:48 PM
03/21/11 10:48 PM
hp383
State of Confusion
OK thanks for the info. I will try one.
Rock Auto did have a listing for a tilt column switch, but it was the kind that mounts at the bottom of the column.
[Re: hp383]
#955999
03/21/11 11:03 PM
03/21/11 11:03 PM
Posts: 18,416 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Most aftermarket listings are screwed up. I would call a dealer and get the oem number and see what it crosses to.
