Re: 440 electronic conversion?
[Re: 05dakota]
#955637
03/21/11 05:21 PM
03/21/11 05:21 PM
RapidRobert
No exp w it but for cheap and just as good, get a 440 elec dist from a JY and a $15 black 4 pin Mopar ECU from a parts house and take apart the dist & solvent wash/dry/lube & might ch the vac adv can & for sure toss the heavy spring w the long loop on one end. Lastly would b your choice of coil and the right ohm ballast to go along w it. Many options there. You'll save money & if you tweek each dist subsystem in order you'll b happy w the outcome.
[Re: 05dakota]
#955639
03/21/11 05:26 PM
03/21/11 05:26 PM
RapidRobert
Yeah they dont call this the rust belt for nothing. Easier would b to buy one in the BB parts for sale here to your mailbox
[Re: 05dakota]
#955640
03/21/11 05:35 PM
03/21/11 05:35 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
no way will i find a jy 440 dist up here in rusty upstate ny.
you should be able to buy one rebuilt from the parts store , but the NEW MP units have an adjustable mech advance which makes setting them up much easier ?
Why don't you want a Pertronix ? The electronics is just as reliable , or unreliable , as an MP box .
[Re: 05dakota]
#955642
03/21/11 05:43 PM
03/21/11 05:43 PM
JohnRR
U.S.S.A.
Have had 2 ignitors fail on me.
How old were they ???
[Re: 05dakota]
#955643
03/21/11 05:44 PM
03/21/11 05:44 PM
RapidRobert
Which ones were they as I've been wanting to do my 1st pertronix conversion (prob a II) w the correct flamethrower coil for the II kit
[Re: 05dakota]
#955646
03/21/11 05:52 PM
03/21/11 05:52 PM
JohnRR
U.S.S.A.
neither had more than 5000 miles on it.
Considering you don't go anywhere .. ... The I must have been pretty old and before they moved manufacturing OVER THERE , so I'm surprised it failed so soon , the II ???.
