alt.? #955221
03/21/11 12:46 PM
03/21/11 12:46 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
gm one wire.when i rev the motor it pegs the volt guage.is this somthing i can troble shoot or does it need to go to the shop.
Re: alt.? [Re: bonefish] #955222
03/21/11 02:37 PM
03/21/11 02:37 PM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
You might want to contact these folks. They can likely help you out. www.madelectrical.com
Ted
Re: alt.? [Re: DusTed74] #955223
03/21/11 02:43 PM
03/21/11 02:43 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I would suggest going to the shop, these have an internal regulator, sounds like it is not working correctly . . .
Re: alt.? [Re: bonefish] #955224
03/21/11 04:52 PM
03/21/11 04:52 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Either the regulator is bad or you don't have it proberly hooked to the battery. Take a test meter and check battery voltage. If it follows the dash gauge and goes high, it's a problem in the "one wire."
Re: alt.? [Re: bonefish] #955225
03/21/11 05:32 PM
03/21/11 05:32 PM
Either/or ASAP as w it "full fielding" it'll fry the batt and or wiring & if you have to drive it for a short period of time your actually better off unhooking the alt & going off of the batt & running it down some.
Re: alt.? [Re: RapidRobert] #955226
03/21/11 07:05 PM
03/21/11 07:05 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
is a internal reg somthing i can pick up at napa and install myself?
Re: alt.? [Re: bonefish] #955227
03/21/11 10:19 PM
03/21/11 10:19 PM
not sure but a friendly/knowledgeable counterman may b able to ans that & you might open it up & see if it looks easily acessible.
Re: alt.? [Re: RapidRobert] #955228
03/22/11 12:19 AM
03/22/11 12:19 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
no comprenday.
Re: alt.? [Re: bonefish] #955229
03/22/11 12:20 AM
03/22/11 12:20 AM
no comprenday.
even at NAPA
