Rebuild cone type sure-grip?
#955035
03/21/11 09:13 AM
03/21/11 09:13 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
Has anyone rebuilt a cone type sure-grip? I know it is said that they're non-rebuildable but I found this on the site: http://www.moparts.org/Tech/Archive/axle/13.htmlSounds pretty simple to rebuilt and cheaper than a clutch type (I have access to a machining shop). Correct me if I'm wrong but the sure-grip is a result of the friction of the cone and the case? That way I could machine the cones several times before the unit will be rendered useless. I could get a cone unit for $120 - seller has no info about internal condition (got it part of a package deal) - original seller said it's ok. Good price?
Re: Rebuild cone type sure-grip?
[Re: bigsbigelow]
#955038
03/21/11 10:17 AM
03/21/11 10:17 AM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I rebuilt mine. I took 0.080" off each cone in a lathe and then put it back together with two 0.040" shims. Been on the car like that for 5 years and still working fine.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#955039
03/21/11 02:13 PM
03/21/11 02:13 PM
Posts: 1,322 Michigan
crlush
did the same thing, worked perfect.
[Re: Russ_Davis]
#955041
03/21/11 02:47 PM
03/21/11 02:47 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Just pulled one out of my dads challenger - 383 4 speed car - he bought it new and it now has 114,000 miles on it It lasted that long towing, daily driving and the occasional blast down the track with slicks. One side was shot -the other cone was fine, but instead of band-aiding it he went with a Eaton Truetrac to get another 100k out of the rear
[Re: DJVCuda]
#955042
03/21/11 03:27 PM
03/21/11 03:27 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I just picked one up for $40 in perfect working condition. Give it a shot. It's a good price
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: DGS]
#955044
03/21/11 06:10 PM
03/21/11 06:10 PM
Posts: 15,487 Florida
scratchnfotraction
a member here on the board sell SS washer ready to install with directions on the how too Trwaters IIRC maybe PM him for a set of the washers/spacers and go for it I have seen a few still going after one rebuild so far i will be doing mine soon as well good luck and post pics of the build
[Re: JohnRR]
#955047
03/27/11 10:37 AM
03/27/11 10:37 AM
Posts: 2,129 Vermont
TrWaters
Vermont
The rebuild is just a bandaid for a pisspoor design, think about why it needs to be rebuilt and the procedure. The cones have bottomed out, why ? Because they self destruct every time you make a turn. The gear oil is getting filled with small metal chips from this self destruction.
GIVE IT UP MAN!!!!!!!! A recent study shows that the worn cone material actually dissolves in the gear oil.
Yes, I have correct sized stainless shims made specifically for these. PM or email me.
[Re: TrWaters]
#955049
03/27/11 11:15 AM
03/27/11 11:15 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Tom, I'm not trying to take business from you but the cone type is what it is ... a bad design , but it does excel in one area , it generates business for replacement
Look at the current auburn cone type, it's a bigger piece of carp than the old Borg Warner
