Rebuild cone type sure-grip? #955035
03/21/11 09:13 AM
03/21/11 09:13 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Has anyone rebuilt a cone type sure-grip? I know it is said that they're non-rebuildable but I found this on the site: http://www.moparts.org/Tech/Archive/axle/13.html
Sounds pretty simple to rebuilt and cheaper than a clutch type (I have access to a machining shop).
Correct me if I'm wrong but the sure-grip is a result of the friction of the cone and the case? That way I could machine the cones several times before the unit will be rendered useless.
I could get a cone unit for $120 - seller has no info about internal condition (got it part of a package deal) - original seller said it's ok. Good price?
Re: Rebuild cone type sure-grip? [Re: DGS] #955036
03/21/11 10:05 AM
03/21/11 10:05 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Price doesn't seem too bad considering new units are over $500. I say try it. I would have with mine but I am swapping my cone type for a clutch type my father gave me. The rebuild procedure definitely makes sense but when I talked to ring and pinion shops, they all told me cone types are NOT rebuild-able. Maybe they have not seen the Moparts tech archives.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Rebuild cone type sure-grip? [Re: DGS] #955037
03/21/11 10:16 AM
03/21/11 10:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The rebuild is just a bandaid for a pisspoor design, think about why it needs to be rebuilt and the procedure. The cones have bottomed out, why ? Because they self destruct every time you make a turn. The gear oil is getting filled with small metal chips from this self destruction.
Re: Rebuild cone type sure-grip? [Re: bigsbigelow] #955038
03/21/11 10:17 AM
03/21/11 10:17 AM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I rebuilt mine. I took 0.080" off each cone in a lathe and then put it back together with two 0.040" shims. Been on the car like that for 5 years and still working fine.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Rebuild cone type sure-grip? [Re: Mick70RR] #955039
03/21/11 02:13 PM
03/21/11 02:13 PM
crlush Offline
crlush  Offline
did the same thing, worked perfect.
Re: Rebuild cone type sure-grip? [Re: crlush] #955040
03/21/11 02:33 PM
03/21/11 02:33 PM
Pittsfield, Mass.
Russ_Davis Offline
Russ_Davis  Offline
Pittsfield, Mass.
I've done a half dozen with several on the bench. Never had any problems with street cars. Won't last long racing. These lasted long lives from the factory, and there cheap and not hard to change.
Re: Rebuild cone type sure-grip? [Re: Russ_Davis] #955041
03/21/11 02:47 PM
03/21/11 02:47 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Just pulled one out of my dads challenger - 383 4 speed car - he bought it new and it now has 114,000 miles on it
It lasted that long towing, daily driving and the occasional blast down the track with slicks.
One side was shot -the other cone was fine, but instead of band-aiding it he went with a Eaton Truetrac to get another 100k out of the rear
Re: Rebuild cone type sure-grip? [Re: DJVCuda] #955042
03/21/11 03:27 PM
03/21/11 03:27 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I just picked one up for $40 in perfect working condition. Give it a shot. It's a good price
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Rebuild cone type sure-grip? [Re: 69L78Nova] #955043
03/21/11 04:14 PM
03/21/11 04:14 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I'll give it a shot - $120 doesn't seem to be a bad price. Although the true condition is unknown it looks fairly nice!
Re: Rebuild cone type sure-grip? [Re: DGS] #955044
03/21/11 06:10 PM
03/21/11 06:10 PM
scratchnfotraction Offline
a member here on the board sell SS washer ready to install with directions on the how too
Trwaters IIRC
maybe PM him for a set of the washers/spacers and go for it
I have seen a few still going after one rebuild so far
i will be doing mine soon as well
good luck and post pics of the build
Re: Rebuild cone type sure-grip? [Re: scratchnfotraction] #955045
03/21/11 06:40 PM
03/21/11 06:40 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Dr Diff has the shims as well.
Re: Rebuild cone type sure-grip? [Re: RobX4406] #955046
03/21/11 09:28 PM
03/21/11 09:28 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I've machined several of them. Although not as strong a unit as the other, they have always worked fine. And I have never shimmed the gears, either.
Master, again and still
Re: Rebuild cone type sure-grip? [Re: JohnRR] #955047
03/27/11 10:37 AM
03/27/11 10:37 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
GIVE IT UP MAN!!!!!!!! A recent study shows that the worn cone material actually dissolves in the gear oil.
Yes, I have correct sized stainless shims made specifically for these. PM or email me.
Re: Rebuild cone type sure-grip? [Re: TrWaters] #955048
03/27/11 10:51 AM
03/27/11 10:51 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
An earlier study suggested that as the metal cones wear, the particles are vaporized, and expelled out through the axle vent.
TR Waters
Re: Rebuild cone type sure-grip? [Re: TrWaters] #955049
03/27/11 11:15 AM
03/27/11 11:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tom, I'm not trying to take business from you but the cone type is what it is ... a bad design , but it does excel in one area , it generates business for replacement
Look at the current auburn cone type, it's a bigger piece of carp than the old Borg Warner
