8 1/4 sure grip notched cross shaft #954993
03/21/11 12:43 AM
03/21/11 12:43 AM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
Where can I find a 8 1/4 sure grip notched cross shaft for installing 4.10 gears?
Re: 8 1/4 sure grip notched cross shaft [Re: mopars4ever] #954994
03/21/11 12:37 PM
03/21/11 12:37 PM
md
md
btt
Re: 8 1/4 sure grip notched cross shaft [Re: mopars4ever] #954995
03/21/11 02:02 PM
03/21/11 02:02 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
pm sent
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: 8 1/4 sure grip notched cross shaft [Re: kissmyaspen] #954996
03/21/11 02:22 PM
03/21/11 02:22 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
is this shaft factory or aftermarket? i bought and ran a used 4.10/8 1/4 but replaced it as it was very noisy and thought it possibly was a cobbled up set up not intended to use 4.10's.
Re: 8 1/4 sure grip notched cross shaft [Re: maxwedge1] #954997
03/22/11 03:08 AM
03/22/11 03:08 AM
md
md
It is actually the large pin that the axles touch when installed. For 4.10 and above(IIRC)the pin has to have a notch to allow the installation of the axles. You rotate the pin and install one axle then rotate the pin again to install the other due the the thickness of the ring gear.
Re: 8 1/4 sure grip notched cross shaft [Re: mopars4ever] #954998
03/22/11 09:40 AM
03/22/11 09:40 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
You can actually just grind the inside tooth edge of several ring gear teeth to get the clearance for a regular pin. The pinion gear never makes contact with the ring gear on the edge. I did it in my old 340-4spd Duster with 4.10's in the 8.25 rearend and no ill effects or noise.
I'm not sure MP still makes the special pin for 4.10 and up gears but it used to be in their catalog. A regular pin can also be machined for the notch.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 8 1/4 sure grip notched cross shaft [Re: MY340] #954999
03/22/11 10:59 AM
03/22/11 10:59 AM
md
md
I would think the pin would still be available since they still sell the gears but I can`t seem to find one.
Re: 8 1/4 sure grip notched cross shaft [Re: mopars4ever] #955000
03/22/11 12:04 PM
03/22/11 12:04 PM
md
md
found one, thanks
