exhaust valve stuck 3 times now. help? #954958
03/20/11 11:55 PM
03/20/11 11:55 PM
florida
rxod Offline OP
rxod  Offline OP
florida
I just rebuilt a 318 for my 73 dart swinger. I did the port work on the stock heads and sent them out to a machine shop for new steel guides and smaller 11/32 stem valves (increased valves size to 1.905/1.6). They also put in pc valve seals, comp cams springs and retainers. After about 50 miles, the #4 exhaust valve stuck open and bent the push rod. Took the head off and back to the machine shop. They said the stem had galled itself to the guide, probably from oil starvation. So, they put a new valve in as well as a bronze guide to fix it. When I reassembled the motor, I used an old valve cover with the top cut off so I could observe the oil flow. Oil was flowing abundantly through the stock rocker shafts and running out to the tip of the valves. Seemed good to me. Drove it for 5 miles and "bink", it siezed again, this time #2 exhaust.
Called the machine shop and they were baffled, so they said they would try to open up the stem to guide clearance from 1 thou to 1.4 thou. They installed another new valve and bronze guide. I thought my stock rockers may not be pushing enough oil to the stem tips so I replaced all of the rockers with new stock ones, observed the oil again, all seemed good. Drove it for 5 miles, and "bink", #2 stuck again.
My question is do you think that the positive type valve seals are starving the valve stems? should I go back to umbrella seals? This is very frustrating. Please help.
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954959
03/21/11 12:02 AM
03/21/11 12:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would go back to umbrellas but seizing in five miles seems like theres something else going on.....
Re: exhaust valve stuck 3 times now. help? [Re: 1_WILD_RT] #954960
03/21/11 12:06 AM
03/21/11 12:06 AM
florida
rxod Offline OP
rxod  Offline OP
florida
The machine shop also said they could not detect any oil on the bad valve stems when they disassembled them, yet oil is flowing and pooling up in the head. Just seems like the seals are preventing proper lubrication.
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954961
03/21/11 12:10 AM
03/21/11 12:10 AM
IN
ahy Offline
ahy  Offline
IN
Steel guides are a stock rebuild fix (that along with knurled valves, I've used myself at one time). I'd use the stock umbrella seals... or rebuild to "high po" specs with all bronze guides... and look for a different machine shop for the next project. Since you have checked the oiling, sounds like the PC seal + steel guide setup doesn't work so well.
Re: exhaust valve stuck 3 times now. help? [Re: ahy] #954962
03/21/11 12:14 AM
03/21/11 12:14 AM
ill
dennismopar73 Offline
ill
sounds as if the guides to 'tight ' exs, the exhaust side
j m o
Re: exhaust valve stuck 3 times now. help? [Re: dennismopar73] #954963
03/21/11 12:27 AM
03/21/11 12:27 AM
florida
rxod Offline OP
rxod  Offline OP
florida
Did I mention that this machine shop specializes in Fords??
The strange thing is that the third time they failed was with the bronze insert. These were Ferrera SS valves. They tell me that they put these seals on every head they do. Has any one used these pc seals on early heads with stock rockers? Maybe early heads weren't designed for this type of oiling, rather relied on splashing oil on the stems like with umbrellas?
Re: exhaust valve stuck 3 times now. help? [Re: dennismopar73] #954964
03/21/11 12:28 AM
03/21/11 12:28 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
with todays erratic fuels and possible mixture problems I like to set EXHAUST stem clearance at LEAST 2 thou.
bronze guides CAN go 1/2 a thou tighter than a steel guide provided they are finished correctly. (straight) but we didn't think it was worth it and just went.002+ on all exhaust regardless of guide material
the shop owner ALWAYS insisted we error on the loose side on exhausts.
Re: exhaust valve stuck 3 times now. help? [Re: SSAAHemiFan] #954965
03/21/11 12:31 AM
03/21/11 12:31 AM
florida
rxod Offline OP
rxod  Offline OP
florida
Is there positive or negative pressure at the stem on exhaust?
I've read both. Negative from outflowing gases, positive from the exhaust pressure.
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954966
03/21/11 09:43 AM
03/21/11 09:43 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Guide to stem clearance were set up too tight from the start. extra needed on exhaust, thats the side that takes all the heat and expansion.
logan426
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954967
03/21/11 10:23 AM
03/21/11 10:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are the PC valve seals the white Teflon seals ?
If so there is a big part of your problem. You need to pull both heads , take them back to the machine shop , probably expect to replace all the exh valves and switch to a viton seal or an umbrella seal.
Re: exhaust valve stuck 3 times now. help? [Re: JohnRR] #954968
03/21/11 09:16 PM
03/21/11 09:16 PM
florida
rxod Offline OP
rxod  Offline OP
florida
not sure if teflon or not, but I will find out. whats the problem with teflon? thanks
Re: exhaust valve stuck 3 times now. help? [Re: MLR426] #954969
03/21/11 09:31 PM
03/21/11 09:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
logan426
I had the same problem on a set of BB heads I had done.. The above statement is the truth.
I am truckless..
Re: exhaust valve stuck 3 times now. help? [Re: 340SHORTY] #954970
03/21/11 09:49 PM
03/21/11 09:49 PM
florida
rxod Offline OP
rxod  Offline OP
florida
So, should I open the exhaust clearance upto 2 thou and keep the pc seals if they are viton, or go with umbrellas?
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954971
03/22/11 12:43 AM
03/22/11 12:43 AM
Delray beach, Florida
P
Performance Only Offline
P
i'm wondering why they went with steel guides in the first place.
i agree with the others, the clearances were too tight for an exhaust valve.
just curious, where in Fl. are you? just wondering if your anywhere near my shop in Delray beach.
machine shop owner and engine builder
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954972
03/22/11 01:01 AM
03/22/11 01:01 AM
umbrellas
Re: exhaust valve stuck 3 times now. help? [Re: RapidRobert] #954973
03/28/11 01:10 AM
03/28/11 01:10 AM
florida
rxod Offline OP
rxod  Offline OP
florida
Performance Only- I'm in Orlando.
I am having umbrellas put on the exhaust, clearance to 2 thou and leaving the pc seals on the intakes @ 1.5 thou. Hope it works, cause I'm over taking these heads off.
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954974
03/28/11 01:33 AM
03/28/11 01:33 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Sounds to me like machine shop did not do guides right,or valve sets cut to deep. Running hydralics right.
Re: exhaust valve stuck 3 times now. help? [Re: 268RTs4ME] #954975
03/28/11 02:39 AM
03/28/11 02:39 AM
florida
rxod Offline OP
rxod  Offline OP
florida
yes. hydraulics
Re: exhaust valve stuck 3 times now. help? [Re: rxod] #954976
03/28/11 10:30 AM
03/28/11 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They are harsh on the valve stems , not good for a street engine , so I have read ?
I'd change them out while the heads are off and apart .
