Harmonic balancer removal #954834
03/20/11 08:27 PM
03/20/11 08:27 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Tried to remove the balancer on a 440 and cannot get the bolt to budge! Tried a little heat and plenty of breaker bar and nothing. Any tricks out there for this? I am going to get an impact tomorrow and try that, but I've removed plenty and never had one this tight!
Re: Harmonic balancer removal [Re: indytex96] #954835
03/20/11 08:30 PM
03/20/11 08:30 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Find a pipe to go over the breaker bar and make it longer.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Harmonic balancer removal [Re: indytex96] #954836
03/20/11 08:33 PM
03/20/11 08:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Put a socket and breaker bar on it. Position the bar against the frame and have someone bump the starter over. Be carefull bar needs to hit the top of the left frame rail or bottom of the right.
Re: Harmonic balancer removal [Re: indytex96] #954837
03/20/11 08:51 PM
03/20/11 08:51 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Use an impact gun to take it off it's ok. To put it on NO!!
Re: Harmonic balancer removal [Re: JonC] #954838
03/20/11 09:11 PM
03/20/11 09:11 PM
SE Kansas
I
I
SE Kansas
I have tried a long bar on the breaker bar and even tried the starter trick. Any good ideas on how to hold the engine from turning over other than wedging a nail bar in the teeth on the convertor as its a bear to hold? Should I try more heat?
Re: Harmonic balancer removal [Re: indytex96] #954839
03/20/11 09:30 PM
03/20/11 09:30 PM
SE Kansas
I
I
SE Kansas
Stupid question, but the bolt is counter-clockwise like normal for removal, right?
Re: Harmonic balancer removal [Re: NITROUSN] #954840
03/20/11 09:39 PM
03/20/11 09:39 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
If that doesn't work.........well IDK??
It is right hand thread. Righty tighty, lefty loosey.
Re: Harmonic balancer removal [Re: indytex96] #954841
03/20/11 09:40 PM
03/20/11 09:40 PM
yes, jack the front end up so you have room for a long cheater on the breaker bar. I wouldn't do anything w the flywheel teeth
