#954834 - 03/20/11 06:27 PM Harmonic balancer removal
indytex96 Offline
Loc: SE Kansas
Tried to remove the balancer on a 440 and cannot get the bolt to budge! Tried a little heat and plenty of breaker bar and nothing. Any tricks out there for this? I am going to get an impact tomorrow and try that, but I've removed plenty and never had one this tight!
#954835 - 03/20/11 06:30 PM Re: Harmonic balancer removal [Re: indytex96]
HemiRick Offline
Loc: Memphis
Find a pipe to go over the breaker bar and make it longer.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
#954836 - 03/20/11 06:33 PM Re: Harmonic balancer removal [Re: indytex96]
NITROUSN Offline
Loc: UPPER MICHIGAN, MARQUETTE COUN...
Put a socket and breaker bar on it. Position the bar against the frame and have someone bump the starter over. Be carefull bar needs to hit the top of the left frame rail or bottom of the right.
#954837 - 03/20/11 06:51 PM Re: Harmonic balancer removal [Re: indytex96]
JonC Offline
Loc: Millinocket, Maine
Use an impact gun to take it off it's ok. To put it on NO!!
#954838 - 03/20/11 07:11 PM Re: Harmonic balancer removal [Re: JonC]
indytex96 Offline
Loc: SE Kansas
I have tried a long bar on the breaker bar and even tried the starter trick. Any good ideas on how to hold the engine from turning over other than wedging a nail bar in the teeth on the convertor as its a bear to hold? Should I try more heat?
#954839 - 03/20/11 07:30 PM Re: Harmonic balancer removal [Re: indytex96]
indytex96 Offline
Loc: SE Kansas
Stupid question, but the bolt is counter-clockwise like normal for removal, right?
#954840 - 03/20/11 07:39 PM Re: Harmonic balancer removal [Re: NITROUSN]
tmef Offline
Loc: Independence, KS
If that doesn't work.........well IDK??
It is right hand thread. Righty tighty, lefty loosey.
#954841 - 03/20/11 07:40 PM Re: Harmonic balancer removal [Re: indytex96]
Loc: Lincoln Nebraska
yes, jack the front end up so you have room for a long cheater on the breaker bar. I wouldn't do anything w the flywheel teeth
25,696 Registered Members
196,730 Topics
Are cassettes making a comeback?
by DUFFMAN
Yesterday at 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
Yesterday at 10:31 PM
Basic ignition question, using MSD-6AL and MSD-8680 boxes
by Fab64
Yesterday at 10:29 PM
318 head flow
by skrews
Yesterday at 09:35 PM
