Hey electricians-UPDATED W PICS
#95480
07/27/08 01:15 PM
07/27/08 01:15 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
I am trying to wire a old fan up to help exhaust my paint booth. My old one died. I have a newer mod fan, squirre cage type that has a junction box and many different types of wires. I attempted to use the white and black like my old fan, but it just hums and goes no where. There is also a red wire, I believe a blue wire, yellow and then two brown wires that went to some sort of selenoid thats now gone.
Any ideas. I just want it hard lined in and want to by pass the selanoid if possible.
LAWFISH
Re: Hey electricians-need help on an exhaust fan!
[Re: Sub95]
#95483
07/27/08 03:20 PM
07/27/08 03:20 PM
RUMBLON
Cambridge Idaho
Diagram i have it says
white is Com black is hi red is low blue is med high yellow med low
browns goto RC run ccapacitor
So It will not work using high and common. so i guess I have to run it through the capactor or I cant use it????
LAWFISH
[Re: RUMBLON]
#95484
07/27/08 03:29 PM
07/27/08 03:29 PM
Posts: 1,868 Cali S.B
Sub95
super gas
super gas
Cali S.B
[Re: 72challorange]
#95486
07/27/08 04:30 PM
07/27/08 04:30 PM
The browns go to the run cap, and it must be the correct value for the motor, within reason. Be sure to use a RUN cap not a start cap. "Most" of the time, start caps are black plastic, and run caps have oblong or round metal shells
Also I would NOT use black. (High speed.)
At least check the nameplate, and measure amperage draw. This sounds like an old furnace fan, which is designed to run against ductwork, which, believe it or not, LOWERS the amperage draw. Most furnace A/C fan/ blowers, when run with no ductwork, will "overamp"
I'd use white and red. I've done this with several fans for my friends, over the years, and usually, even on low speed, these will tend to draw max. amps with no ductwork attached.
Be sure to tape up unused wires!!!!
Re: UPDATED WITH PICS.
[Re: RUMBLON]
#95487
07/27/08 04:52 PM
07/27/08 04:52 PM
RUMBLON
Cambridge Idaho
This is the fan in question. The capacitor is with this one but when turned on, it ONLY HUMS. This is another fan I used to use but when it started only humming, I switched it out or tried too. Here are two pics. So if I can find a capacitor, then my troubles should be over? The numbers appear to be #97F5705 ????? VERY HARD TO READ AND FADED.
