Rebuilt 727 no reverse! #954583
03/20/11 04:24 PM
03/20/11 04:24 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I just got my car fired back up with the rebuilt trans, converter,cooler and lines and got it filled up with fluid all gears work except reverse? Any ideas? I havent got ahold of the tranny guy yet. He is 4 hours away from me!
67' charger 499 RB 10.57 at 127
Re: Rebuilt 727 no reverse! [Re: dragram440] #954584
03/20/11 04:48 PM
03/20/11 04:48 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
did you put a trans brake in it?
Re: Rebuilt 727 no reverse! [Re: dragram440] #954585
03/20/11 06:08 PM
03/20/11 06:08 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
did u check detent?? if detent is off, u will burn up the trans!! check ur pressure too
Re: Rebuilt 727 no reverse! [Re: dragram440] #954586
03/20/11 10:42 PM
03/20/11 10:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The low/reverse band circuit is the problem. Look at the rear servo,rear band strut, or a valve body issue. The servo and band can be air checked with the valve body removed. You may find a cocked or broken piston,missing band strut,or incorrect adjustment. As metioned some trans brake valve bodys need the brake applied to engage reverse.
Good luck Doug
Re: Rebuilt 727 no reverse! [Re: dragram440] #954587
03/20/11 11:04 PM
03/20/11 11:04 PM
iowa
wesw Offline
wesw  Offline
iowa
if it has a trans brake you have to push the button for it to go into reverse
598 ci predator
Re: Rebuilt 727 no reverse! [Re: dvw] #954588
03/20/11 11:07 PM
03/20/11 11:07 PM
bigfork mn
bigfork mn
The tranny is a 727 with a full manual turbo action cheeta reverse pattern shift no engine brake in 1st no trans brake coan 8" converter.
Re: Rebuilt 727 no reverse! [Re: dragram440] #954589
03/21/11 08:27 AM
03/21/11 08:27 AM
I bet you have a ripped rear servo seal. Chyeck line pressure with air and see if you hear air leaking out the rear servo.
Re: Rebuilt 727 no reverse! [Re: dragram440] #954590
03/21/11 08:28 AM
03/21/11 08:28 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I had the same problem once. I pulled the transmission 3 times to find the problem. I finally found the pump was different , I don't know what darn difference there was but I changed it and that fixed it. Good luck.
6.50 @105.26
Re: Rebuilt 727 no reverse! [Re: Kindafast] #954591
03/21/11 09:08 AM
03/21/11 09:08 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
You've got to be kidding me. Is he going to pay for your gas to bring it back? I might be going to the cities soon I could drop it off at Lofgrens.
Re: Rebuilt 727 no reverse! [Re: dvw] #954592
03/21/11 01:17 PM
03/21/11 01:17 PM
bigfork mn
bigfork mn
Good luck Doug
Can I see all that by pulling just the pan or do I have to pull the valve body or should I just pull the trans back out and start from there?
Re: Rebuilt 727 no reverse! [Re: dragram440] #954593
03/21/11 03:19 PM
03/21/11 03:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are you sure it goes into third gear ?? It shares the front clutch with reverse. Thats why I say be sure it goes into third and if it does then I agree its most likely a reverse band problem. Ron
Re: Rebuilt 727 no reverse! [Re: 383man] #954594
03/21/11 03:41 PM
03/21/11 03:41 PM
bigfork mn
bigfork mn
I havent driven the car but it stalls higher in secound and higher in yet third in the garage. Still to much snow and mud to drive it.
Re: Rebuilt 727 no reverse! [Re: dragram440] #954595
03/21/11 09:49 PM
03/21/11 09:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I would pull the pan and look for obvious distress in the rear servo and band linkage. If there's nothing obviously amiss pull the VB and air test the rear servo.
Re: Rebuilt 727 no reverse! [Re: dragram440] #954596
03/22/11 10:53 PM
03/22/11 10:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Good luck Doug
Can I see all that by pulling just the pan or do I have to pull the valve body or should I just pull the trans back out and start from there? [/quote
Yes the valve body would have to come out. All bands and clutches can be tested with air. My diagnosis was based on the fact that 3rd gear works correctly. If not I would air check the front clutch passage. 3rd and reverse both use the high/forward clutch . The low/reverse band is only used in reverse with a Chettah valve body.
Doug
Re: Rebuilt 727 no reverse! [Re: dvw] #954597
03/22/11 11:01 PM
03/22/11 11:01 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
DROP the pan and pull-down on the lever on the rear servo and report back.
Re: Rebuilt 727 no reverse! [Re: John_Kunkel] #954598
03/23/11 10:00 PM
03/23/11 10:00 PM
NC
440Jim Offline
440Jim  Offline
NC
Re: Rebuilt 727 no reverse! [Re: 440Jim] #954599
03/28/11 11:24 AM
03/28/11 11:24 AM
bigfork mn
bigfork mn
So I pulled the pan and the reverse servo lever is completely free swinging, so im guessing the rear band is broken or off and the lever doesnt seem to line up with the center of the servo.My tranny guy said it was nothing that he did wrong? Not sure why this happened! The tranny has 0 miles on it! Time for a new tranny guy. Now that I have had him do this one twice now with a total of 8 passes on the first one and 0 on this one.
Re: Rebuilt 727 no reverse! [Re: dragram440] #954600
03/28/11 11:28 AM
03/28/11 11:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the strut for the rear band in the bottom of the pan ? Interesting that it doesn't line up with the servo. How does he know it was nothing he did when he hasn't seen it yet ?
I think you need to become your OWN tranny guy , they aren't that hard to do .
Re: Rebuilt 727 no reverse! [Re: dragram440] #954601
03/28/11 11:35 AM
03/28/11 11:35 AM
tboomer Offline
tboomer  Offline
Too bad you are not closer...Bad1970dust does a bang up job on 727s...
Re: Rebuilt 727 no reverse! [Re: JohnRR] #954602
03/28/11 11:48 AM
03/28/11 11:48 AM
bigfork mn
bigfork mn
No strut in botom of pan.
