edelbrock performer rpm 440 heads #954397
03/20/11 11:27 AM
03/20/11 11:27 AM
madison, ohio
modified1090 Offline OP
madison, ohio
any one change there springs on a set of these?
what did you put on them and if you dont mind me asking why did you go with what you did?
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954398
03/20/11 12:40 PM
03/20/11 12:40 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
You can use any spring that has up to aprox 1.56" dia. and 1.88" installed height. If your just replacing what you have, comp 911 are comparable. If your trying to match a cam, your cam manf. can select one. I'm running Isky 9935 wiyh a solid roller cam.
Re: edelbrok performer rpm 440 heads [Re: 66er] #954399
03/20/11 01:26 PM
03/20/11 01:26 PM
madison, ohio
madison, ohio
i am running the mopar purple shaft .590 312 duration cam. i cannot find any recommendations for this anywhere.
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954400
03/20/11 01:33 PM
03/20/11 01:33 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Try a Comp Cams 928, installed @ 1.875"
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954401
03/20/11 01:34 PM
03/20/11 01:34 PM
tboomer Online work
tboomer  Online Work
Isky 8000a?
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954402
03/20/11 01:40 PM
03/20/11 01:40 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
i ran the isky 8005A with the same set up that you have but with 1.6 indy roller rockers. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: edelbrok performer rpm 440 heads [Re: mopar65] #954403
03/20/11 01:42 PM
03/20/11 01:42 PM
tboomer Online work
tboomer  Online Work
I had the wrong number!! Yes...8005A..
Re: edelbrok performer rpm 440 heads [Re: mopar65] #954404
03/20/11 01:46 PM
03/20/11 01:46 PM
madison, ohio
madison, ohio
where the valves replaced or did you still have the same valves that came from edelbrock? don't get me wrong i want to do the right thing i just don't want to spend a lot of money. (i think most of us feel that way)
Re: edelbrok performer rpm 440 heads [Re: S/ST 3040] #954405
03/20/11 01:47 PM
03/20/11 01:47 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I ran those for a while with a .600" flat tappet cam. Fit like a glove
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954406
03/20/11 01:50 PM
03/20/11 01:50 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Run the same valves. You can upgrade to your locks and retainers without spending a lot of $.
Re: edelbrok performer rpm 440 heads [Re: mopar65] #954407
03/20/11 01:51 PM
03/20/11 01:51 PM
madison, ohio
madison, ohio
did u have to cut the seat pockets for the smaller id of the inner spring? or did u just shim for the difference in installed height between the edelbrock and isky recomend, i think the difference is only .010" is that enough to worry about?
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954408
03/20/11 02:09 PM
03/20/11 02:09 PM
mopar65 Offline
mopar65  Offline
did u have to cut the seat pockets for the smaller id of the inner spring? or did u just shim for the difference in installed height between the edelbrock and isky recomend, i think the difference is only .010" is that enough to worry about? [/quot
Hi no there is enough room that the springs fit fine and i did not reshim them. i checked a few to compare and thye were so close on mine i did not think it was the worth the trouble to shim the new springs. i used the stock valves but went to a 10 degree reatainer/keeper that set up worked fine for the 3 years i had the car untill i sold it.thanks mopar 65
Re: edelbrok performer rpm 440 heads [Re: modified1090] #954409
03/20/11 02:13 PM
03/20/11 02:13 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
the old mopar book said 140 sit pression,
Re: edelbrok performer rpm 440 heads [Re: cbarracuda] #954410
03/20/11 02:23 PM
03/20/11 02:23 PM
madison, ohio
madison, ohio
thanks, i know that the spings on the heads now are only rated at 115 seat psi 280@.500"
Re: edelbrock performer rpm 440 heads [Re: modified1090] #954411
03/20/11 02:31 PM
03/20/11 02:31 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have done several sets of eddys small and big block. What has worked every time on big block is adding a red or blue comp inner spring to the original spring with comp retainer #741-16 steel or 732-16 titanium. This is to get 340-350 at .600 lift and 150-160 seat pressure. The original springs are borderline to stiff for hyd cams and borderline to weak for solid cams. The original springs from edel. will work the way they are if not revving over 6000 rpm. If the edel. springs are new, the blue should work, if the edel. springs have a couple hundred runs on them try the red inner. red part#975-16, blue part#974-16. These are around $30 at summit. Steel retaners and locks will be around $80. tit. retainers will shock you at around $320 with locks.
Re: edelbrock performer rpm 440 heads [Re: qwkmopardan] #954412
03/20/11 04:18 PM
03/20/11 04:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nice info. Thanks
Re: edelbrock performer rpm 440 heads [Re: qwkmopardan] #954413
03/20/11 05:52 PM
03/20/11 05:52 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Likewise for me, just went through my collection of old springs until I found a set of inners that gave me the right pressure. When I pulled the 312/590 out and went with the 304/640 ultradyne, I upgraded to crower spriings and Titanium retainers.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: edelbrock performer rpm 440 heads [Re: MoparBilly] #954414
03/20/11 06:06 PM
03/20/11 06:06 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
was the U/D 640 faster then the 590 cam
1.39 9.85 - 137 mph
Re: edelbrok performer rpm 440 heads [Re: 66er] #954415
03/20/11 07:45 PM
03/20/11 07:45 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Same here, Eddie valves, 1.6 rockers with .600" net lift with Comp 928's, stable to 7000+ rpm. Do yourself a favor and have the valve guide clearances checked, mine were tight and I have heard MANY reports of the same.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: edelbrok performer rpm 440 heads [Re: 67Charger] #954416
03/20/11 09:43 PM
03/20/11 09:43 PM
My eddy heads had the same tight valve guide issue as well.
