I just change the hangers and installed everything back again. What a diffrence. It look awesome with the hurst slick just close to the front of the wheel opening and the ride height get much better - I use the higher hole before when the mancini ones was installed.
I now have the stock coronet ones. I couldnt go for the stock plymouth ones because the tire havent had clearance in the front.
The MP adjusteble pinion snubber did also fit now! It dident reach to the floor - just into nowhere in the wheel hoop...
If I remeber right the mancini ones was marked with 015?
The bad thing is that I have to shorten the drive shaft but its so worth it!
