Re: Balljoint swap with front rack?
[Re: SLOW67]
#954130
03/20/11 06:16 PM
03/20/11 06:16 PM
Posts: 6,145 Melbourne , Australia
LA360
Your ackerman angle will be incorrect if you swap ball joints over from one side to the other. Put simply, there should be a straight line between the steering arm, ball joint and the centre of the rear axle on both sides. If you are having trouble visualizing that, I suggest a search on Google, as there are many articles online available. On top of that you then have Bump steer to worry about, but that is more concerned with the tie rod length, position of the steering rack etc.
Alan Jones
[Re: SLOW67]
#954135
03/20/11 07:32 PM
03/20/11 07:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So what happens? Every body I've asked says it causes "problems" but is never specific about what it does
Part of your issue will be the rack itself... you need the inner tie rod end(end of the rack) to be AT the same place as the lower control arm inner pivot point (where the T bar is)... that way the tie rod will end up being the same length as the lower control arm BUT your K-member is in the way and you need to get full travel on the spindle... you could change(build) a new upper A-arm the same length as the lower BUT look where that point would be... not good
[Re: SLOW67]
#954137
03/20/11 08:19 PM
03/20/11 08:19 PM
MR_P_BODY
So using this theory my custom steering arms should sit outward closer to the wheel and tire to maintain the relationship with the rear axle/balljoint centerline correct? How much of a deviation from this line would be acceptable? On the rack mounting, rule of thumb is 3in from the rack centerline to the steering arm centerline correct?
The end of the steering are(outer tie rod end) you will have in line with the centerline of the lower ball joint.... that 3" on the tie rod end will work in a drag car(but it will still scuff on the turns) but you would like it straight
[Re: SLOW67]
#954139
03/20/11 08:54 PM
03/20/11 08:54 PM
Posts: 928 NC
SLOW67
NC
[Re: SLOW67]
#954140
03/20/11 09:04 PM
03/20/11 09:04 PM
MR_P_BODY
So this will owrk then? (see attachment) the cardboard is a mock up of the steering arm. The first pic is just general to show the setup the second is a view from the top of the spindle with both balljoint holes lined up...
I assume its in line with the ball joint.... you can raise that point IF needed so its on the same plane as the rack
[Re: MR_P_BODY]
#954142
03/20/11 09:19 PM
03/20/11 09:19 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The best thing you can do is take measurements of the locations of the inner an d outer tie rod ends from the stock setup. This will provide you with a very good base point for properly locating the position of the new ends. Also you need to look at the length of the steering arms that were used with the rack in its original configuration. I had to shorten mine considerably. They are now half as long as before. Ignore the bad ackerman in my deal, it works OK on the track only. To learn all about setting this deal up properly, there is a chapter in the chassis manual (or was) that describes bump steer and how to corect it, along with other info.
[Re: SLOW67]
#954143
03/20/11 09:30 PM
03/20/11 09:30 PM
MR_P_BODY
When its all held up its inline with the balljoint...carboard is hard to work with lol. I just want my angles to be right because this is mostly a street car Thanks for all the help guys oh btw MR_P_BODY I've been following your front suspension build and its giving me all these bad ideas lol keep up the great work
I got mine all squared away... I have about 1" of off set, I can live with that... not perfect but Ok. You MAIN issue will be using a upper control arm... being that its shorter than the lower... as the spindle drops down the upper edge will swing in quicker and cause your toe to go out... NOT GOOD.... unless you can some how get the rack and tie rod at the same point as the lower ball joint(both height and length) so they pivot on the same arc as the lower arm does... what I'm trying to say is the rack needs to be at the lower control arm inner pivot point and the outter tie rod needs to be at the ball joint height and be on that same center line.... pretty much impossible with the wheel and tire in the way
[Re: SLOW67]
#954146
03/20/11 10:15 PM
03/20/11 10:15 PM
Posts: 9,848 MI, usa
dvw
MI, usa
There are 2 issues. First is Ackerman. The purpose of Ackerman is to allow the inner wheel to turn in a tighter radius than the outer wheel. Think about a tight turn. The turning radius of the inner wheel could be half of the outer. By swapping the ball joints/steering arms the inner tire will turn in a larger radius than the outer causing tire scrub. It will cause toe in when turning,not good. The second issue is bump steer. Simple to figure out. Looking from the front of the car 4 points need to form a parallelogram. The inner tie rod,outer tie rod,lower control arm pivot,lower ball joint. Move the steering arm in the correct location and all will be OK. If not it'll drive like crap. Doug
