E-Body Hemi Engine Mounts - Experts Needed #953822
03/19/11 05:18 PM
03/19/11 05:18 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I recently took over a restoration of 70 Challenger R/T SE orig 440 car, now with 426 Hemi and 5 Speed Keisler Setup. I have some issues with the motor mounts on the Hemi and need some expert advice on what I need to do to correct it. The engine and tranny are in the car but I really need to insure the motor and tranny are in the correct places. The car has a correct Hemi K-Member but as you can see in the pictures the motor is sitting way low on the drivers side and is not all the way down on the passenger side. Do I have the correct mounts? Can I correct the problem with out pulling the motor back out?
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953823
03/19/11 05:20 PM
03/19/11 05:20 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
More
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953824
03/19/11 05:23 PM
03/19/11 05:23 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
From up top
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953825
03/19/11 05:28 PM
03/19/11 05:28 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
driver side
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953826
03/20/11 03:30 PM
03/20/11 03:30 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Are you using an original Hemi K-Frame and engine brackets?
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953827
03/20/11 03:59 PM
03/20/11 03:59 PM
CrazyD Offline
CrazyD  Offline
engine trans assembly is supported at 3 points (2 engine & 1 trans mount)which means it should always settle down on all three. It can't be hanging in the air on 2 mounts - Something must be holding up that pass side.
1) is the pan hung up on the k frame
2) is exhaust, headers etc clear of T bars
3) Is the stud on the pass insulator IN the hole on the pass engine bracket, or is it hung up underneath the bracket?
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: faud88] #953828
03/20/11 04:14 PM
03/20/11 04:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My b-body fits tight. I would take that left bolt out. Raise the motor and get the right side to go in place as you lower it. With the bolt in as you have it there is no way the right side will drop in...
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: CrazyD] #953829
03/20/11 04:24 PM
03/20/11 04:24 PM
CrazyD Offline
CrazyD  Offline
also check that driver's header - can't tell from picture but it looks like maybe it's wedged under your ps box, which might not let the engine settle down on the pass side
Re: E-Body Hemi Engine Mounts - Experts Needed [Re: CrazyD] #953830
03/20/11 05:14 PM
03/20/11 05:14 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Are you using an original Hemi K-Frame and engine brackets? Yes and Yes
1) is the pan hung up on the k frame - No all clear
2) is exhaust, headers etc clear of T bars All Clear
3) Is the stud on the pass insulator IN the hole on the pass engine bracket, or is it hung up underneath the bracket? It is resting on the mount not in the hole.
I appreciate the help. I think the best thing to do is pull the motor back up as suggested and get the right side down on the mount. Hopefully all will drop into place.
