fan shroud questions #953804
03/19/11 04:34 PM
03/19/11 04:34 PM
tx
N
nobrakesneeded Offline OP
N
tx
I had a small block (basically stock)built by a shop to install into my street rod. After about 1000 miles, the motor has developed a loud lifter knock upon start up and at speed after driving about 10 minutes.
When the motor was installed I had a single electric fan mounted to an aftermarket aluminum radiator. The single fan would not cool the motor in traffic so I added a second, both pullers. These fans were mounted to a sheetmetal shroud loosely based on a Be Cool setup I had seen on a blown big block car. The setup cooled the car as expected.
THe engine builder is convinced the fans and shroud are cooking the motor and wants a conventional motor driven fan and standard shroud installed before he commits to replacing the lifters under a very generous warranty.
What are your experiences with stock vs. aftermarket fan/shroud setups?
Re: fan shroud questions [Re: nobrakesneeded] #953805
03/19/11 04:44 PM
03/19/11 04:44 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If I had paint peeling on the hood, it wouldn't have anything to do with my worn out tires.
The above makes just as much sense as your situation. Even a overheating engine will not make a lifter or cam go bad, That is an oiling or "cam break in" issue.
Good luck with the fan shroud though.
Re: fan shroud questions [Re: nobrakesneeded] #953806
03/19/11 07:37 PM
03/19/11 07:37 PM
what's your oil psi (at both places)
Re: fan shroud questions [Re: RapidRobert] #953807
03/19/11 08:41 PM
03/19/11 08:41 PM
tx
N
N
tx
oil pressure is constantly between 70 and 75 psi.
When the issue was first discussed with the builder, I was told the lifter noise was possibly a result of an oversized lifter bore allowing excessive movement.
Re: fan shroud questions [Re: nobrakesneeded] #953808
03/19/11 10:56 PM
03/19/11 10:56 PM
It's certainly not a lack of PSI . I would see what you have for preload on em & press down on each of the rocker arms (the pushrod side) w a wooden hammer handle while it's idling & see if you can isolate the bad one (or ones) (it'll get quieter). One or more of the lifters may have went bad but I'd check preload 1st
