Automatic Overdrive recommendations for E body #953536
03/19/11 10:44 AM
03/19/11 10:44 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Are there any trans swaps that would allow me to retain a functional factory slap stick? what are my options? Thanks.
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953537
03/19/11 11:20 AM
03/19/11 11:20 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
A 518 from a Dodge van or truck would allow you to use your Slap Stick shifter. You will have to fab a bracket to hold the bottom of the torque shaft that goes thru the floorpan though. There is no provision to mount the stock bracket that bolts to the bottom of the tailshaft of a 727. I plan on using a 518 in a Cuda that I have as a future project.
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953538
03/19/11 11:55 AM
03/19/11 11:55 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Will that unit or the A500 trans fit the tunnel?
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953539
03/19/11 12:03 PM
03/19/11 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are more than likely going to have to cut on the car , i'n not sure if there is a difference between the OD section from the 500 to the 518. someone did post up pictrues of ribs on the side of the OD section being cut close to the case but I don't know if doing that will stop you from having to cut the Tbar crossmember some still.
Re: Automatic Overdrive recommendations for E body [Re: JohnRR] #953540
03/19/11 12:11 PM
03/19/11 12:11 PM
JDMopar Offline
JDMopar  Offline
Who was the guy that used to post here that had a B-body with a 518 and a turbo'd motor? He did a really good job of modding the crossmember. You can cut on some of the bracing on a 518 and it will fit the torsion bar x member. I honestly don't remember seeing pics of a 500 installed in a B or E body.
Re: Automatic Overdrive recommendations for E body [Re: JDMopar] #953541
03/19/11 12:35 PM
03/19/11 12:35 PM
AZ
Mike P Offline
Mike P  Offline
AZ
I've been researching the 727 to 518 swap for a few weeks now and the 518 is really probably going to be the best bet if for no other reason than the OD is electrically actuated.
With something like a superbell on a 700R4 or other off brand OD the slap stick would require an additional detent to engage all the gears.
The 518 is also a whole lot better option than a gear vendor bolted on to the transmission.
For what it’s worth to give you an idea on size here some pictures:
Stock SB 727
518
And Gear Vendor
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953542
03/19/11 12:39 PM
03/19/11 12:39 PM
Ohio, USA
Donny Offline
Donny  Offline
Ohio, USA
Not looking to steal any thunder from this thread but I have been contemplating alternatives to a 3sp auto for my Dart project. I am pretty clueless as to what is out there and what will work, so I will ask here.
I would really like a 4sp auto for my SB, so what are my options, which are the best options? Gear Vendors sounds interesting but I am not fully versed on the pros and cons of GV either?
Re: Automatic Overdrive recommendations for E body [Re: Donny] #953543
03/19/11 12:52 PM
03/19/11 12:52 PM
AZ
Mike P Offline
Mike P  Offline
AZ
At one point the GV was the "hot setup" but that was simply becasue it was the only option out there that retained the 727 transmission. Floor pan modifications to get it in were pretty extensive.
The GV unit by itself usually cost more than a rebuilt 518 even without a core. Additionally depending on which version of the 518 you choose you can also get the Torque Convertor lock up feature.
Re: Automatic Overdrive recommendations for E body [Re: Donny] #953544
03/19/11 12:57 PM
03/19/11 12:57 PM
East Lansing, Michigan
O
OldHippie Offline
super gas
OldHippie  Offline
super gas
O
Not to long back there was fellow that sold a '68-ish Valiant with an advertised 518 trans swapped in. The E-mail address with the add was (I think) Jarnos@msn.com. I thought he was possibly connected to the Vignogna (SP) family. This might be a good place to start seeking information?
The Old Hippie Hisself
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953545
03/19/11 01:06 PM
03/19/11 01:06 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Anyone have reveiws on the Keisler unit?
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953546
03/19/11 03:30 PM
03/19/11 03:30 PM
IN
ahy Offline
ahy  Offline
IN
Mopar Action put a Keisler in a BB Road Runner and seemed to like it.
Re: Automatic Overdrive recommendations for E body [Re: ragtop] #953547
03/19/11 03:32 PM
03/19/11 03:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Re: Automatic Overdrive recommendations for E body [Re: DaytonaTurbo] #953548
03/20/11 12:34 AM
03/20/11 12:34 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Just to be clear on the option, there's no extensive floorpan mods in an E body using the Gear vendors..Only the electronic speedo convertor area may need a touch of help...
Re: Automatic Overdrive recommendations for E body [Re: screamindriver] #953549
03/20/11 01:11 AM
03/20/11 01:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Theres none required to put a 518 in either...
Re: Automatic Overdrive recommendations for E body [Re: screamindriver] #953550
03/20/11 01:14 AM
03/20/11 01:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Maybe this is true with the current generation of GV units,
My friend had what is known as a "first generation" GV unit. He had the unit in and out several times trial fitting, removing to bang on the tunnel for clearance and test fitting again. It was like trying to fit in cheapie headers.
Re: Automatic Overdrive recommendations for E body [Re: ahy] #953551
03/20/11 01:17 AM
03/20/11 01:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've performed the Keisler E/B body Auto+4 swap, no floorboard mods are needed, everything is included in the kit, the slapstik is retained, and converted to cable shift, you do have to disassemble the slapstik unit to install the new detent plate, but the shifter retains it original feature, just ads the O/D into the shift, you'll need to mod the factory transmission lines to tie into the braided SS lines that are now on the passenger side,...there is an addition of a TV cable (Throttle Valve) that must be used, basically like a kickdown linkage, but cable,...there is an onboard computer module also, that can be interfaced to reprogram line pressure, shift rpm range, band apply, etc,......the price has come down from it's inception, the final O/D ratio is .70
Re: Automatic Overdrive recommendations for E body [Re: DAYCLONA] #953552
03/20/11 01:22 AM
03/20/11 01:22 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
MORE charity from DAYCLONA! I just read about the Blue Dart in Mopar Action. Nice deed. Nice job.
