62 B window crank handles #953449
03/19/11 01:00 AM
03/19/11 01:00 AM
Western Colorado High Desert
moparmarks Offline OP
How in the kahootince do you get them off. I see the black clip that goes around the shaft and then folded into the handle. Whats the trick??
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 62 B window crank handles [Re: moparmarks] #953450
03/19/11 03:37 AM
03/19/11 03:37 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
There's a special tool to take them off.
Re: 62 B window crank handles [Re: pro6pakRR] #953451
03/19/11 04:32 AM
03/19/11 04:32 AM
Swell. What does the tool do to the clip?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 62 B window crank handles [Re: moparmarks] #953452
03/19/11 07:42 AM
03/19/11 07:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The tool is long obselete.I saw them on Ebay a few times.They go for some major $$$.I made one for my kids 62 and my 57.The clip is actually like a spring.The reg stub is square and has notches in it.I took an old screwdriver and bent the end a bit.Smoothed it down so it didnt gouge the panel.Then you have to get it under the clip where its not held into the handle.Pull it sideways a bit and press it.My kid driled his handles and shafts and installed button allens when he got them off.He didnt reuse the clips.They are a real pain to get off.Rocky
Chrysler Firepower
Re: 62 B window crank handles [Re: therocks] #953453
03/19/11 10:40 AM
03/19/11 10:40 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here's the tool I have: The opening that goes around the square shank on the handle is 1/2" wide. If you're not in a hurry and can't find a tool, PM me. I'll send you the tool and you can send it back when you're done.
Re: 62 B window crank handles [Re: TooMany62s] #953454
03/19/11 10:42 AM
03/19/11 10:42 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here's what the crank looks like on the back side. You need to push the loose end of the "U" clip toward the crank. You may be able to push the door panel in far enough to see the clip.
Re: 62 B window crank handles [Re: TooMany62s] #953455
03/19/11 10:43 AM
03/19/11 10:43 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Another picture:
Re: 62 B window crank handles [Re: TooMany62s] #953456
03/19/11 10:45 AM
03/19/11 10:45 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Re: 62 B window crank handles [Re: TooMany62s] #953457
03/19/11 11:34 AM
03/19/11 11:34 AM
Ok I have a few of those GM clip tools. I can see the clips as I have ripped the door panels off.
I'll try again today.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 62 B window crank handles [Re: TooMany62s] #953458
03/19/11 11:36 AM
03/19/11 11:36 AM
Thats what I was thinking when I saw it.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
