What is the best carbuetor cleaner in a dip bucket? #953086
03/18/11 12:13 PM
03/18/11 12:13 PM
Bloomington, Illinois
BS23V0B178891 Offline OP
What is the best carbuetor cleaner in a gallon dip bucket?
Re: What is the best carbuetor cleaner in a dip bucket? [Re: BS23V0B178891] #953087
03/18/11 12:26 PM
03/18/11 12:26 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Be careful with those. They do a great job, but sometimes to great a job. Carbs can get "to" clean. The butterfly shaft holes in the base plate will wear, and fill with grime over time. So when you use a carb. dip it will clean the grime out, but you'll have a big vacuum leak you'll have a problem tracking down.
Re: What is the best carbuetor cleaner in a dip bucket? [Re: BS23V0B178891] #953088
03/18/11 12:30 PM
03/18/11 12:30 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
CHEM-DIP is what I use.
Re: What is the best carbuetor cleaner in a dip bucket? [Re: Ply72rr] #953089
03/18/11 12:37 PM
03/18/11 12:37 PM
Elk Grove, Calif.
Elk Grove, Calif.
They make that "shtuff" (yes, correct spelling) smell any better yet?
Re: What is the best carbuetor cleaner in a dip bucket? [Re: bigblock340power] #953090
03/18/11 01:42 PM
03/18/11 01:42 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Look for a product with methylene chloride in it. Nasty stuff, very toxic but that's why it works.
Kevin
Re: What is the best carbuetor cleaner in a dip bucket? [Re: Twostick] #953091
03/18/11 02:06 PM
03/18/11 02:06 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
If you are working in a attached garage take it outside and FAR away from the house. My wife has put up with fumes, fires and small explosions but that stuff had to get off the premises RIGHT NOW ...... and I agreed 100%
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: What is the best carbuetor cleaner in a dip bucket? [Re: finadk] #953092
03/18/11 02:23 PM
03/18/11 02:23 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'm not sensitive to chemical fumes at all but carb-dip stuff makes me dizzy FAST if I'm not totally outdoors with it.
And make sure to wear THICK rubber gloves, thin gloves will split open at some point and that carb cleaner WILL make your skin flake off - for about a week.
Re: What is the best carbuetor cleaner in a dip bucket? [Re: Fury Fan] #953093
03/18/11 02:34 PM
03/18/11 02:34 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i`ve used the NAPA brand with good results. the main body(holley 4160) does not fit in the can though. i used some oven cleaner on it, scrubbed it with a tooth brush and rinsed it in a bucket of hot water. rinsing and changing the water a few times. do not leave the oven cleaner on the carb for more than 5 minutes. it came out really clean.
Re: What is the best carbuetor cleaner in a dip bucket? [Re: 65rbdodge] #953094
03/18/11 02:43 PM
03/18/11 02:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you want to try a simple home brew it will work on all but the nastiest carbs. Buy a gallon (2-3 Gallons is better for coverage) of pure Acetone (Home Depot sells it), pour it all into an approriate sized METAL container with a tight fitting lid, dump all the Acetone in then add 1-2 quarts of transmission fluid and 1-2 quarts of Dot 3 or Dot 4 brake fluid. Soak the carbs overnight or longer depending on buildup. Save some pure Acetone for the final rinse off.
*Warnings:
This fluid will likely strip any painted parts and melt or damage anything that is not made of metal (rubber,plastic, etc.).
The Acetone is bad for you and soaks into skin immediately, wear rubber gloves and work in a well ventilated area
The Acetone will evaporate very quickly, keep the lid on your mix or it will not work for long.
You'll be surprised at how well it works!
Re: What is the best carbuetor cleaner in a dip bucket? [Re: ScottSmith_Harms] #953095
03/18/11 06:58 PM
03/18/11 06:58 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
*Warnings:
The Acetone will evaporate very quickly, keep the lid on your mix or it will not wrok for long.
Remember acetone has a flash point of zero degrees - keep away from sparks and flame! Are you using the brake fluid to strip paint or to hold down the evaporation? Sounds like a neat formula.
Old, tired, and sometimes broke down. Me, not my car...
Re: What is the best carbuetor cleaner in a dip bucket? [Re: Shoozy] #953096
03/18/11 07:09 PM
03/18/11 07:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not for paint removal specifically, it has very good "creep" and gets into very small nooks and crannies, it works well to break down most petrochemicals (as does transmission fluid).
Re: What is the best carbuetor cleaner in a dip bucket? [Re: Ply72rr] #953097
03/18/11 07:55 PM
03/18/11 07:55 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I've used the same. Left one of the float bowls in for a couple of hours when I got sidetracked with something else. When I took it out later, most of the finish on the bowl was long gone.
Re: What is the best carbuetor cleaner in a dip bucket? [Re: rss] #953098
03/18/11 09:14 PM
03/18/11 09:14 PM
PENNSYLVANIA
GARAGEMAN Offline
GARAGEMAN  Offline
PENNSYLVANIA
lacqure thinner at your near by auto paint store.been using it for years
