Re: Water Pump length
[Re: PowerWagonDude]
#952809
03/17/11 10:30 PM
03/17/11 10:30 PM
RapidRobert
Is the early 273 water pump snout shorter?
Yes, overall length (depth) is shorter. EDIT If you need even more room than that not sure if the MP race (early 273 type) one or there's an aftermarket one also w iirc the outlet on the pass side if either is shorter than the OE 273 pump & not likely & even if they are it wouldn't b much but you can mill the front of the tim cover for some gain there and that's actually a good move as it reduces the vane to the flat recess in the t cover which will make the pump far more efficient & adj your bolt/washer/pulley alignment to compensate of course and an anti cav plate on the vanes works good
[Re: RapidRobert]
#952810
03/18/11 08:55 AM
03/18/11 08:55 AM
Posts: 711 Montana
Posest
Montana
I am looking for a shorter pump for the 408 in my Dakota. The one I have is off of a pre 68'and is cast iron. It does fit but the bottom outlet is on the drivers side. If you have any links that would be great! Thanks Shawn
[Re: Posest]
#952811
03/18/11 09:04 AM
03/18/11 09:04 AM
RapidRobert
No Shawn I dont remem what brand it was so you might google it and I'll give it some more thought & if it comes to me I'll PM you
#952812
03/18/11 05:44 PM
03/18/11 05:44 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Long WP measures 5.547" from rear to pulley flange face.
Short WP measures 4.75"
