Water Pump length #952808
03/17/11 09:17 PM
03/17/11 09:17 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
I am working on a custom project that requires radiator clearance. It is a 1939 Plymouth with a 1987 Dodge 360. Is the early 273 water pump snout shorter? Or is there a short water pump available?
Re: Water Pump length [Re: PowerWagonDude] #952809
03/17/11 10:30 PM
03/17/11 10:30 PM
Yes, overall length (depth) is shorter. EDIT If you need even more room than that not sure if the MP race (early 273 type) one or there's an aftermarket one also w iirc the outlet on the pass side if either is shorter than the OE 273 pump & not likely & even if they are it wouldn't b much but you can mill the front of the tim cover for some gain there and that's actually a good move as it reduces the vane to the flat recess in the t cover which will make the pump far more efficient & adj your bolt/washer/pulley alignment to compensate of course and an anti cav plate on the vanes works good
Re: Water Pump length [Re: RapidRobert] #952810
03/18/11 08:55 AM
03/18/11 08:55 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I am looking for a shorter pump for the 408 in my Dakota. The one I have is off of a pre 68'and is cast iron. It does fit but the bottom outlet is on the drivers side. If you have any links that would be great!
Shawn
Re: Water Pump length [Re: Posest] #952811
03/18/11 09:04 AM
03/18/11 09:04 AM
No Shawn I dont remem what brand it was so you might google it and I'll give it some more thought & if it comes to me I'll PM you
Re: Water Pump length [Re: PowerWagonDude] #952812
03/18/11 05:44 PM
03/18/11 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Long WP measures 5.547" from rear to pulley flange face.
Short WP measures 4.75"
Re: Water Pump length [Re: Posest] #952813
03/18/11 10:50 PM
03/18/11 10:50 PM
I am looking for a shorter pump for the 408 in my Dakota. The one I have is off of a pre 68'and is cast iron. It does fit but the bottom outlet is on the drivers side. If you have any links that would be great!Thanks Shawn
P4876548, Wont b cheap. EDIT pass inlet
Re: Water Pump length [Re: RapidRobert] #952814
03/18/11 11:45 PM
03/18/11 11:45 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I think it would be cheaper to go with a new radiator. Thanks for the info.
