Are there any tricks to help seating rings... #952767
03/17/11 09:06 PM
03/17/11 09:06 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Buddy has an engine that sat around for a while, while the car was being built. Engine runs fine, just low on compression due to the rings never fully seating. I've heard their are a few tricks to help seat them even after having run the car for 200 + miles.
The scariest trick that was told to me was pouring a teaspoon of Ajax into each spark plug hole, then firing it up
Anyone have any tried and true tricks of the trade, other than tearing it down
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Are there any tricks to help seating rings... [Re: BloFish] #952768
03/17/11 10:12 PM
03/17/11 10:12 PM
SW CO
HemiSportFury Offline
SW CO
Not Ajax.
Bon Ami, sprinkled down the carb as the engine was running.
At lease that what I used to hear when I first started working on cars, about 50+ years ago!
Never tried it and wouldn't recommend it. Run it hard or tear it down.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Are there any tricks to help seating rings... [Re: HemiSportFury] #952769
03/17/11 10:25 PM
03/17/11 10:25 PM
Run it hard
X2 and read "breakin secrets" at www.mototuneusa.com (5 minute read) & no bon ami/ajax
Re: Are there any tricks to help seating rings... [Re: HemiSportFury] #952770
03/17/11 10:29 PM
03/17/11 10:29 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
Bon Ami was for chrome rings back in 1960. I never tried it tho'
Modern rings either break in during the first few minutes, or they don't. It depends on the quality of the cylinder wall hone as far as I am concerned.
Re: Are there any tricks to help seating rings... [Re: RapidRobert] #952771
03/18/11 03:18 AM
03/18/11 03:18 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Run it hard
I read this link posted by Rapid Robert and first thought... "Easy for THEM to recommend I wail on a fresh motor... Its not THEIR engine." It began to sink in after reading similar arguements elsewhere. I posted a question.. "How long do I have to wait until I can Peel out?" Look it up. NOBODY suggested to baby it for 500 miles like it says in many old school owners manuals. It seemed abusive to me at first. I sold new cars in the 80s and since then, I had the imprint in my brain that new or rebuilt components need to be driven with care.
In 2004 when I built the 440/493, I drove it REAL easy during the first 500 miles, then changed the oil. In the next 2500 miles, it used oil, got slower and eventually started smoking . I pulled the motor out to hone it and put in new rings.
Re: Are there any tricks to help seating rings... [Re: Kern Dog] #952772
03/20/11 11:13 AM
03/20/11 11:13 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
The first thing they do on a dyno is run the engine for about 15 minutes with a slight load on it at about 2500. this gets everything up to temp, fluid leaks checked, timing set, cam break in if flat tappet.
After that its an all out assault. After that, the rings are broken in (or not if there was a problem)
Re: Are there any tricks to help seating rings... [Re: torkrules] #952773
03/20/11 11:37 AM
03/20/11 11:37 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
was always told that if you break a motor in like a wuss it will run like a wuss....lol
i always break the cam in. make sure there are no leaks and or problems. then i drive it kinda easy to the main road which is maybe 2 miles away then its hammer down.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Are there any tricks to help seating rings... [Re: BloFish] #952774
03/20/11 11:43 AM
03/20/11 11:43 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I agree that proper cylinder wall prep is the single most important factor. By proper I mean that besides the obvious ie. perfectly round with no taper that the finish should be appropriate for the type of rings used. Most modern moly filled rings like a pretty smooth finish. Excessive oiling of the rings and/or too gentile a break in can cause glazing and excessive oil consumption. Putting the engine under a brief load in the higher gears and then letting off the gas quickly can help seat the rings. Sometimes the use of a non-detergent oil for the first 100 miles or so can help with rings that are slow to seat. Regarding compression and oil consumption, I have seen engines with good leak down and compression #s that used oil. I've also seen just the opposite, very little oil consumption, but poor test results. Good luck.
Re: Are there any tricks to help seating rings... [Re: 5spdcuda] #952775
03/20/11 11:52 AM
03/20/11 11:52 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
WHO HERE likes a dingle-berry hone ?
Re: Are there any tricks to help seating rings... [Re: dOrk !] #952776
03/20/11 11:55 AM
03/20/11 11:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Great glaze breaker. Have 2 different sized ones.
Re: Are there any tricks to help seating rings... [Re: buildanother] #952777
03/20/11 12:00 PM
03/20/11 12:00 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
WHICH grits ? ... what brand and price?
I have a MH 413(dished pistons) that I am putting some std bore(flat-top) pistons in-it. NICE bores ...all I think is that the bores need to be scuffed-up a tad.
Re: Are there any tricks to help seating rings... [Re: dOrk !] #952778
03/20/11 12:01 PM
03/20/11 12:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Use a real hone...if you want your rings to seat correctly.
Re: Are there any tricks to help seating rings... [Re: buildanother] #952779
03/20/11 12:06 PM
03/20/11 12:06 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Built many race engines for the roundy round guys. Break the glaze with a dingle berry (i like that name) hone. Start the engine, break in the cam and lifters and go racing. Everytime breakin an engine low and slow they ran that way. The only real problem is that on a fresh engine built to stock specs the bearing clearances are usually tighter and you really need a good oil for the first hour, then drain and go.
Re: Are there any tricks to help seating rings... [Re: RapidRobert] #952780
03/20/11 12:26 PM
03/20/11 12:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Run it hard
buddy told me he does 4-5 burns out to seat the rings. They are either going to seat or not. I burned up the #3 on my supercharged 440 TWICE. Both time I honed the wall real quick then dropped the piston,,, just drove it. Never had any problems.
Coming soon!!!!
Re: Are there any tricks to help seating rings... [Re: dOrk !] #952781
03/20/11 12:27 PM
03/20/11 12:27 PM
chicagoland,usa
chicagoland,usa
Don't recall exact grit, they were right off the tool truck, but seemed to be on heavy grit side.
Re: Are there any tricks to help seating rings... [Re: Challenger 1] #952782
03/20/11 12:29 PM
03/20/11 12:29 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Is someone here OFFERING a loaner ?
Re: Are there any tricks to help seating rings... [Re: dOrk !] #952783
03/20/11 12:36 PM
03/20/11 12:36 PM
chicagoland,usa
chicagoland,usa
It's a SUNNEN too! Aren't all our garages filled with inexpensive equipment like that?
Re: Are there any tricks to help seating rings... [Re: buildanother] #952784
03/20/11 12:44 PM
03/20/11 12:44 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I do HEAR YOU ..... the only people that can afford long-dollar stuff like this ....
...... are energy REsellers ! (don't I wish)
Re: Are there any tricks to help seating rings... [Re: dOrk !] #952785
03/20/11 12:49 PM
03/20/11 12:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
Nope...it comes from getting up everyday at 5:30 AM everyday for 26 years now and making sure 5-10 guys have work for the day. And then working smart all day long for a long time. That's where it come from.
I'm at work right now, wrenching on dirty greasy trucks so I don't have to pay someone else to do it, That's how I work smart to make money.
Where you at? you making at money today?
Re: Are there any tricks to help seating rings... [Re: Challenger 1] #952786
03/20/11 12:53 PM
03/20/11 12:53 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
... you mean it is not nearly TRIPLING their cost of LPG ... like they are doing to little-old-ladies up-here in Michigan ?
