440 PISTONS #952610
03/17/11 03:50 PM
03/17/11 03:50 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Can anyone tell me what compression specs are for a trw piston #2292 it has been discontinued
thanks
Re: 440 PISTONS [Re: AB&E] #952611
03/17/11 04:25 PM
03/17/11 04:25 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
thanks
I have tried all other resources & dead end
Re: 440 PISTONS [Re: AB&E] #952612
03/17/11 05:40 PM
03/17/11 05:40 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Are you sure of the 2292 number? 2292s appear to be Ford 390 pistons??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 PISTONS [Re: AB&E] #952613
03/17/11 05:49 PM
03/17/11 05:49 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
R U able to measure the compression distance/height ?
Re: 440 PISTONS [Re: Von] #952614
03/17/11 06:12 PM
03/17/11 06:12 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
motor is at machine shop & I am 99% sure that is the #. I came up with same thing ford. I guess I will have to wait untill the machine shop tells all. I am not one to wait
Re: 440 PISTONS [Re: AB&E] #952615
03/17/11 06:13 PM
03/17/11 06:13 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Any chance they are 2295s? 2295s are a dome piston. Not sure off hand how big of a dome, probably .100 or so.
Re: 440 PISTONS [Re: AB&E] #952616
03/17/11 06:13 PM
03/17/11 06:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
is it a flat top piston or does it have a dome ? 2295 is a 440 dome piston , should be 12.0
Re: 440 PISTONS [Re: JohnRR] #952617
03/17/11 07:00 PM
03/17/11 07:00 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Hey John
I was hoping you would chim in
I do not know much about engine internalls.
But I am pretty sure these are flat tops they have a indent in the middle of piston & they look the same as the ones in my 383 on the floor. so if they are the correct #s & they are flat tops what would they be on compression
Re: 440 PISTONS [Re: JohnRR] #952618
03/17/11 08:42 PM
03/17/11 08:42 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
John where did ya go
I rechecked pistons & they are trw #2292p & they are for sure flat tops
thanks
Re: 440 PISTONS [Re: AB&E] #952619
03/18/11 09:19 AM
03/18/11 09:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks
No idea then , but it should be easy to figure out , find out the bore size and how far in the hole , or out , the piston sticks , does it have valve reliefs ? I've never seen a dish piston in a 440 , even the low compression pig motors .
Re: 440 PISTONS [Re: AB&E] #952620
03/18/11 01:17 PM
03/18/11 01:17 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Hey John
Since that is a 390 Ford piston not a 440 piston, bore size is more than 1/4" too small and the compression distance is more than 1/4" too low.
The compression would be ZERO.
Re: 440 PISTONS [Re: GomangoCuda] #952621
03/18/11 02:20 PM
03/18/11 02:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hey John
Re: 440 PISTONS [Re: JohnRR] #952622
03/18/11 04:14 PM
03/18/11 04:14 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
I get the picture
But that is the # on piston.
So I will just wait untill machine shop gets to me & see what I got.
thanks
Re: 440 PISTONS [Re: AB&E] #952623
03/18/11 04:37 PM
03/18/11 04:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No idea what the number is, I can't see them from here to know what it is your are talking about.
If that is truly the number that is coming back as a ford 390 piston, so you are either working on a ford 390 and you think it's a 440 or the pistons are mismarked ???? or what you think is a TRW number is NOT.
Re: 440 PISTONS [Re: JohnRR] #952624
03/18/11 04:51 PM
03/18/11 04:51 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
John John
I said I was not real keen on engine internalls. But I am not a complete idiot So no reason for going that direction again I was just looking for help.
thanks
Re: 440 PISTONS [Re: AB&E] #952625
03/18/11 04:55 PM
03/18/11 04:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John John
thanks
Well you have been told by a number of different people that the number is a FORD 390 piston, all i picture is you doing this ... la la la la la la ... I can't hear you ... without actually SEEING what you are talking about a person can only GUESS , and that doesn't seem good enough for you.
I never said you were an idiot , but if the number is for a 390 piston there can ONLY be two answers ....
Re: 440 PISTONS [Re: AB&E] #952626
03/18/11 08:40 PM
03/18/11 08:40 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
I have a 1982 TRW Engine Parts Specification Manual (for stock parts) and there is no 2292 piston in the book at all. .
Re: 440 PISTONS [Re: GTXX] #952627
03/18/11 08:43 PM
03/18/11 08:43 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
My machine shop has a 1977 book not there either
I will just have to wait & measure pistons to see compression ratio thanks for looking though
Re: 440 PISTONS [Re: AB&E] #952628
03/18/11 11:12 PM
03/18/11 11:12 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
I have a 1980 TRW Performance book too, but can't lay my hands on it. I think it's in the trunk of a car in the basement...
Re: 440 PISTONS [Re: GTXX] #952629
03/19/11 02:33 AM
03/19/11 02:33 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
TRW pistons should have a number starting with L. Sealed Power/Speed Pro pistons should start with a P. Sealed power/Speed Pro forged pistons were TRW pistons with a number change.
Leave the gun.......take the Cannoli's....Mike
