Re: 440 PISTONS
[Re: AB&E]
#952611
03/17/11 04:25 PM
03/17/11 04:25 PM
Posts: 204 washington
AB&E
washington
Can anyone tell me what compression specs are for a trw piston #2292 it has been discontinued thanks
I have tried all other resources & dead end
Re: 440 PISTONS
[Re: AB&E]
#952612
03/17/11 05:40 PM
03/17/11 05:40 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Are you sure of the 2292 number? 2292s appear to be Ford 390 pistons??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 PISTONS
[Re: Von]
#952614
03/17/11 06:12 PM
03/17/11 06:12 PM
AB&E
washington
motor is at machine shop & I am 99% sure that is the #. I came up with same thing ford. I guess I will have to wait untill the machine shop tells all. I am not one to wait
Re: 440 PISTONS
[Re: AB&E]
#952615
03/17/11 06:13 PM
03/17/11 06:13 PM
Von
NE Oklahoma
Any chance they are 2295s? 2295s are a dome piston. Not sure off hand how big of a dome, probably .100 or so.
Re: 440 PISTONS
[Re: JohnRR]
#952617
03/17/11 07:00 PM
03/17/11 07:00 PM
AB&E
washington
Hey John I was hoping you would chim in I do not know much about engine internalls. But I am pretty sure these are flat tops they have a indent in the middle of piston & they look the same as the ones in my 383 on the floor. so if they are the correct #s & they are flat tops what would they be on compression
Re: 440 PISTONS
[Re: JohnRR]
#952618
03/17/11 08:42 PM
03/17/11 08:42 PM
AB&E
washington
is it a flat top piston or does it have a dome ? 2295 is a 440 dome piston , should be 12.0
John where did ya go I rechecked pistons & they are trw #2292p & they are for sure flat tops thanks
Re: 440 PISTONS
[Re: AB&E]
#952619
03/18/11 09:19 AM
03/18/11 09:19 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
No idea then , but it should be easy to figure out , find out the bore size and how far in the hole , or out , the piston sticks , does it have valve reliefs ? I've never seen a dish piston in a 440 , even the low compression pig motors .
Re: 440 PISTONS
[Re: GomangoCuda]
#952621
03/18/11 02:20 PM
03/18/11 02:20 PM
JohnRR
U.S.S.A.
Since that is a 390 Ford piston not a 440 piston, bore size is more than 1/4" too small and the compression distance is more than 1/4" too low. The compression would be ZERO.
Re: 440 PISTONS
[Re: JohnRR]
#952622
03/18/11 04:14 PM
03/18/11 04:14 PM
AB&E
washington
I get the picture But that is the # on piston. So I will just wait untill machine shop gets to me & see what I got. thanks
Re: 440 PISTONS
[Re: JohnRR]
#952624
03/18/11 04:51 PM
03/18/11 04:51 PM
AB&E
washington
John John I said I was not real keen on engine internalls. But I am not a complete idiot So no reason for going that direction again I was just looking for help. thanks
Re: 440 PISTONS
[Re: AB&E]
#952625
03/18/11 04:55 PM
03/18/11 04:55 PM
JohnRR
U.S.S.A.
Well you have been told by a number of different people that the number is a FORD 390 piston, all i picture is you doing this ... la la la la la la ... I can't hear you ... without actually SEEING what you are talking about a person can only GUESS , and that doesn't seem good enough for you.
I never said you were an idiot , but if the number is for a 390 piston there can ONLY be two answers ....
Re: 440 PISTONS
[Re: GTXX]
#952629
03/19/11 02:33 AM
03/19/11 02:33 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
TRW pistons should have a number starting with L. Sealed Power/Speed Pro pistons should start with a P. Sealed power/Speed Pro forged pistons were TRW pistons with a number change.
Leave the gun.......take the Cannoli's....Mike
