Re: #3 and #4 plugs gas soaked
[Re: ireland383]
#952543
03/17/11 01:34 PM
03/17/11 01:34 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Is the firing order correct?4&3 are next to each other on the dist.Rocky
Chrysler Firepower
[Re: ireland383]
#952547
03/17/11 06:21 PM
03/17/11 06:21 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#952548
03/17/11 07:22 PM
03/17/11 07:22 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
What intake?
Weiand 8008 with a Holley 3310. Fuel pressure reads 8 psi. on the gauge which I think is off. I'm running the smaller Summit elec. fuel pump that is supposedly set at 7 psi. If it were too much pressure blowing past the needle and seat wouldn't more than two plugs be soaked? I put some fresh plugs in and will take a spin tomorrow early evening and pull them after.
[Re: SixDRacing]
#952550
03/18/11 01:13 PM
03/18/11 01:13 PM
ireland383
Suffolk,VA
run a clyinder leakage test on #3. eliminate one thing at a time. trouble shoot all systems correctly, and the problem will be found. an oil fouled plug will look gas fouled after it stops firing.
Well just got back from a nice romp and pulled the plugs, all were nice and dry. Did a compression test and held the air in for many minutes on each cylinder and had 165ish across the board. The car always ran fine I just wanted to know why those plugs had so much fuel on them. They were getting spark also. I did shut the pump down as I backed into the driveway. I checked down in the bowls and there wasn't alot of extra fuel in them.
