340 engine1969 or 1970 I.D. help #952423
03/17/11 03:05 AM
03/17/11 03:05 AM
rtplumcrazy1 Offline OP
cast date is 7-9-69, would this engine be for a 69 or 70
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952424
03/17/11 04:12 AM
03/17/11 04:12 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It is probably for a '70.
There should be a partial VIN# on passenger side near oil pan.
Front surface of the block below driver's head will have assy. info (FW340P xxxx xxxx)
Casting date is not a 100% positive way to determine what it was.
Re: 340 engine1969 or 1970 I.D. help [Re: 6bblgt] #952425
03/17/11 04:44 AM
03/17/11 04:44 AM
i could not find any numbers on the pad-nor was there any numbers on the lt side of the block front either-which is unlike the other 340's i checked. Is it possible this block was not stamped, maybe it was a block that was bought over the counter
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952426
03/17/11 05:00 AM
03/17/11 05:00 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have that engines BROTHER! My 340 block has that exact same date! I'll have to look to see if mine is a day or night shift.
I bought mine from a guy in my car club. The block is .030 and has replacement pistons. It came with a truck oil pan and a crank that was already .030 under! The main caps and windage tray were there though.
This motor was first planned to go into a 73 Dart Sport to make a 340 clone car. I ended up using a 360. I may use the 340 in a 71 Duster project later.
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952427
03/17/11 09:58 AM
03/17/11 09:58 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Is there any original paint left on the block or heads? If so, what color?
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952428
03/17/11 10:27 AM
03/17/11 10:27 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
Sometimes you have to take a wire brush to that area of the front of the block just below the drivers side head to be able to read it. I have a 7-11-69 cast 340 block and it's still got factory orange on it.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952429
03/17/11 10:36 AM
03/17/11 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A FACT many seem to forget , ANYONE could walk into a dealership and BUY just a bare block ...
Re: 340 engine1969 or 1970 I.D. help [Re: JOES4FORTY] #952430
03/17/11 12:59 PM
03/17/11 12:59 PM
thanks 4 the info-i did take a wire brush to the machined pad area and the area on the lt hand front side of the block. I found no numbers at all-i did se two very small letters though, but i forget what they were, maybe something like ps.
Re: 340 engine1969 or 1970 I.D. help [Re: rtplumcrazy1] #952431
03/17/11 02:03 PM
03/17/11 02:03 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
I'm starting to see alot of marine engine take out's (Blocks) showing up for sale. Most have no vin #. Most have had a hard life. Check them out good. 340's was the upgrade for the 318 and then went to 360 mid 70's .Just thinking out loud.
Re: 340 engine1969 or 1970 I.D. help [Re: B5 Bee] #952432
03/17/11 03:02 PM
03/17/11 03:02 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Mine is blue. NOT a trace of red or orange anywhere. The block could have been totally stripped at one time and sprayed blue though. Hard to confirm since its 41 years old and has probably been passed around like a biker chick.
Re: 340 engine1969 or 1970 I.D. help [Re: Kern Dog] #952433
03/17/11 04:11 PM
03/17/11 04:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Chrysler Marine engines I'm pretty sure were blue .
