Electric Fuel Pump #952333
03/16/11 11:36 PM
03/16/11 11:36 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
The next step on my Street Rod project is the electric fuel pump. I am looking at the Holley HP 150 gerotor pump. It is supposed to be quieter than a rotary vane pump. I hate electric fuel pump noise so quiet is good. Has anyone used one of these pumps and are they quiet? Any other issues? I am running a 392 Hemi with 1 600 CFM Carter Thunder Series 4 BBL, street only(for now).
Arno
Re: Electric Fuel Pump [Re: B1arno] #952334
03/17/11 12:31 AM
03/17/11 12:31 AM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
I've talked to people that said they are WAY quieter than the Holley Blue pumps. This guy had a Blue and did everything he could to quiet it down and finally replaced it with a Gerator and loved it!
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Electric Fuel Pump [Re: B1arno] #952335
03/17/11 12:48 AM
03/17/11 12:48 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Nice ride!
Re: Electric Fuel Pump [Re: earlybee] #952336
03/17/11 01:43 AM
03/17/11 01:43 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Sweet looking car.
Re: Electric Fuel Pump [Re: demon440] #952337
03/17/11 02:23 AM
03/17/11 02:23 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Nice hot rod! My Mallory 140 was pretty quiet.
Re: Electric Fuel Pump [Re: B1arno] #952338
03/17/11 09:42 AM
03/17/11 09:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Arno
I'd think with that carb a good mechanical should do the trick. It can't move enough gas to justify an electric. Once you get a real carb on that thing you might want to look into an electric unit.
Coming soon!!!!
Re: Electric Fuel Pump [Re: B1arno] #952339
03/17/11 09:52 AM
03/17/11 09:52 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Arno
Any gerotor pump will be far quieter than any vane pump. I like the Mallorys but the Holley gerotor should be fine also.
The sump pump in my house is quieter than a Holley Blue.
Re: Electric Fuel Pump [Re: GomangoCuda] #952340
03/17/11 10:27 AM
03/17/11 10:27 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Arno
yea, but it's also in a hole under the concrete, with a cover on it...and submerged in water
**Photobucket sucks**
Re: Electric Fuel Pump [Re: 70Cuda383] #952341
03/17/11 11:36 AM
03/17/11 11:36 AM
GomangoCuda Offline
GomangoCuda  Offline
And it still kept me up half of last night. GRRRRRRRRRRRR, SHHHHHH, THUMP (Repeat about once a minute)
The point is that you can still hear a Holley Blue with open headers.
Re: Electric Fuel Pump [Re: Mr.Yuck] #952342
03/17/11 03:19 PM
03/17/11 03:19 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Grab a simple inline stock style EFI fuel pump. They will out flow the Holley pumps and are quiet.
As for the Carter, it can easily outflow a stock style fuel pump. I know my old 750 AFB was capable of doing that.
Carter bashers are no different than Holley bashers. They just stick their closed minded heads in different orifices.
- Stu Harmon
Re: Electric Fuel Pump [Re: B1arno] #952343
03/17/11 05:19 PM
03/17/11 05:19 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I ran one on my Hemi Challenger after the mech fuel pump pushrod went bad. Great pump & much quieter than my bro's old blue holley pump. Be sure to mount it with rubber isolators. Only problem is you have to mount it vertically, so its bigger size may be a problem.
Re: Electric Fuel Pump [Re: feets] #952344
03/17/11 09:54 PM
03/17/11 09:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not bashing the carter. I wouldn't run an electric pump unless the car was going to run 11.60's or better. And no need to run one on a 600 cfm carb, no matter the brand. He'd even be ok w/ a 750DP and a mech pump. but that's just my opinion. I've been doing this junk for a while and I've never had a rod or mech pump go bad yet. Your old 750 AFB probably sucked those tiny fuel bowls dry, if ya had a holley you would have been ok..lol
Re: Electric Fuel Pump [Re: Mr.Yuck] #952345
03/18/11 12:20 AM
03/18/11 12:20 AM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks for all the replies and to those that gave to my car. OK, The main reason I am going with an electric pump is at some point I plan on using a more exotic induction. I want to get the car dialed in first and then upgrade. I am not sure what it will be at this point but could be 2x4bbls or as many as 6x2bbls. I was looking at the Holley gerotor but now will check out other brands as well. Thanks again for the input.
Arno
