Whats best coating to store machined parts long term? #951979
03/16/11 01:00 PM
03/16/11 01:00 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Machined parts, Need to store some long term. Humid area. What about gun oil? What are your suggestions?
Re: Whats best coating to store machined parts long term? [Re: galen] #951980
03/16/11 01:07 PM
03/16/11 01:07 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I can tell you from experence that waterproof grease and WD-40 ARE NOT SUFFICIENT to protect an engine block long term.
I use a product called Picklex-20 on sanded metal panels stored inside recoating every 6 months with excellent results.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Whats best coating to store machined parts long term? [Re: galen] #951981
03/16/11 01:53 PM
03/16/11 01:53 PM
Under My Car
Mopar_Country Offline
Under My Car
http://www.cosmolinedirect.com/?gclid=CJL7oOnF06cCFQnrKgod1g5w-A
It's the same thing that firearms are packed in for long term. It's a little messy to remove, but a parts washer will help getting it off. If they are going to be in the shop the indoor/outdoor would probably be your best bet.
Re: Whats best coating to store machined parts long term? [Re: Mopar_Country] #951982
03/16/11 03:44 PM
03/16/11 03:44 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
I've had good luck with CRC SP-400 (p/n 03282). Aerosol can, spray it on & it dries to a waxy coating. Couple layers and it almost becomes like rubber. I use it on the boat, protects hose fittings,hyd. valves, etc from salt water, doesn't wash away.
In order to know what you want, you'll probably have to find out what you don't want.
Re: Whats best coating to store machined parts long term? [Re: fshd4it] #951983
03/16/11 09:37 PM
03/16/11 09:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Cosmoline is a great option. The military stores machined stuff using it and it works.
Don't be the exception.
Re: Whats best coating to store machined parts long term? [Re: Supercuda] #951984
03/17/11 03:17 AM
03/17/11 03:17 AM
Texas
E
ef8Cuda340 Offline
ef8Cuda340  Offline
E
Texas
Another vote for CRC SP-400. I use it to protect fracture surfaces to prevent them from rusting. Also used it on my suspension parts after i wire brushed them.
Re: Whats best coating to store machined parts long term? [Re: ef8Cuda340] #951985
03/17/11 10:29 AM
03/17/11 10:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what about axle grease on the surfaces, then a few silica gel packets on top, and wrap the whole thing up tight with the saran wrap stuff they use in shipping large items?
that was kind of my plan for my big block that just came out of the Dakota, to keep it "fresh" while I do the paint and body on my Cuda.
**Photobucket sucks**
Re: Whats best coating to store machined parts long term? [Re: 70Cuda383] #951986
03/17/11 01:21 PM
03/17/11 01:21 PM
hooziewhatsit Offline
Have you seen this thread?
https://board.moparts.org/ubbthreads/show...e=0#Post6528986
Looks like some neat stuff.
